Question about Singer CE-100 Futura Computerized Sewing Machine
Problems with embrodiery unit
My singer ce100 is beeping and red lights are are flashing when I try to connect the embroidery unit. The thing that the hoop hooks to is supose to move in to pace by it self an dit's not! Can you please help me???
  • bknow Sep 22, 2008
    I have exactly the same problem. My local singer dealer cannot fix it because the macine was bought on-line. They have offered to send the entire unit to the repair facility with a potential cost of $200.
  • bknow May 11, 2010
    Thank you for the suggestions. I did exactly all of these things, as did the Singer Center. My embroidery arm works with other CE-100 but other embroidery units from CE-100 do no work with my machine. It appears the problem may be the the connector inside the machine.
    I am still looking for any other solutions. I do agree this is the most exasperating machine I have used in over 40 years of sewing.
I had this problem with my machine. I did not give up. I got my disk out and tried everything again in sequence. I had not turned the sewing part on the arm to embroidery. It is located where the arm slides on. The key is not to give up too quick. If you have the disk watch the video. Always make sure you use the mesh over your thread or the machine will beep with a red light.
I am an advanced sewer but this is one of the poorest machine I ever bought, with little or no help from the Singer Company.
Posted on Sep 25, 2008
When I thread the bobbin, code 88 flashes, what is that?
Try zero your embroidery hoop carriage by off/on your machine before your next application, if no result disconect your embroidery unit and connect back again ensuring it is properly connected. Hope the problem can be solved.
Jan 17, 2014 | Singer CE-200 Quantum Futura Computerized...
FQ-4 keeps beeping
it's possible that the motherboard that controls the embroidery
has a problem that needs servicing
Dec 22, 2012 | Sewing Machines
How do I delete a previous transmission to my embroidery attachment on my CE100 (Singer Futura)?
try resetting it, take the hoop out, turn the machine off, and then back on, or try detaching the embroidery unit, and then reattach it. I hope this helps :)
Jan 06, 2010 | Singer CE-100 Futura Computerized Sewing...
My start/stop switch will not begin sewing
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
Dec 23, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
The embroidery carriage
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura program.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 04, 2008 | Singer CE-200 Quantum Futura Computerized...
The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer ce-100 futura
Hi justmewynn, The url I am adding to this post may be of help. It is a pdf file from Singer contain many diagrams of the CE-100. Maybe you cqan page through it and find what your looking for. Hope this helps you. http://www.futura-support.com/files/CE100-Eng_Fre_Spa-77153.pdf
Sep 27, 2007 | Singer CE-100 Futura Computerized Sewing...
Beeping
I have had the same problem with my machine as well. have you tryed, keeping it hooked to your computer while sewing, even if you are not using your embroidery unit it still needs to be hooked up, that seems to have helped some with the beeping.
Feb 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
200 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
