Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Problem with the oven - control panel?
We have had this dual fuel range for just over a year. The whole control panel stopped working - oven, vent, etc. We got it replaced after a very long drawn out process with Sears. I used it one time, and now the oven won't heat up. If I go down to the basement and reset the circuit breaker, it will work, but then every time you open the oven door it shuts off and we have to reset it at the circuit breaker again.
Both my husband and I are flat out at work these days and cannot afford to be taking a bunch more days off from work to deal with this oven (we already took off a total of 4 days for Sears incompetence). Any ideas?
  • orange_cat Oct 05, 2008
    Sears guy came out today and found that the power coming from the outlet was not sufficient. It's OK at the circuit box, so we probably have a loose wire in a junction box.
  • Anonymous Dec 29, 2008
    We have the same problem with our range which is less than 2 years old. The power would falter then come back on. This happened a number of times and now the whole thing is just dead.
  • 943 Answers
Hi .thanks for the question. i would check the cord going ito the stove plug .pull it out and look for a discoloring of the brass prongs. also look for loose connection in the stove where the cord attaches to the stove .that could be the problem .thanks the appliance doc rate me please
Posted on Oct 01, 2008
No power to the oven, even LED not lit - gas range on top works OK 0 checked power to oven OK too.
Order part #W10017820 (do this first before you open up the range). While you are waiting for the part to arrivedown load the parts list from kitchenaid.com. When you have the part, Shut offpower to the range. Then remove part 9762612Vent, Center (pull the oven door toward you, you will see four screws). Before you proceed, place a stool with booksor a **** of paper or what ever it takes to equal the height of the bottom ofthe control panel. Then remove part 4457249Face, Control Panel (two screws, right and left, under panel). DO NOT DROP PANEL. The panel is connected via wires so please be careful. Set the panel on the raised surface that youcreated. Replace part W10017820. Replace control panel. Replacecenter vent. Restore power to unit. RP appears in display. Set clock. You're good to go.
Nov 04, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Control Panel Issue
sounds like a contorl board issue it might be going out i suggest get a repair guy out to fix it u can use our directory to find someone near u
Dec 02, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Oct 15, 2008 | Thermador RDF30 Dual Fuel (Electric and...
The colour is coming off the oven knobs and the control panel.(brass fittings)
This is a common problem, I repair these for Rangemaster so I suggets that you contact their customer service department they usually replace then for free
Nov 15, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
335 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
