Question about Philips ProScreen 4750 Impact Multimedia Projector
Ghosting Image I have the same problem as described in http://www.fixya.com/support/t130193-image_problem_projector_ghosting down to the letter. I would like to expand upon the description, however. I was trying to synchronize the picture quality as best as I could with the portable DVD player the projector was connected to. To do this, I repeatedly plugged and unplugged the cable while the movie was paused. After a couple of cycles, the colors realigned, and it instead displaced the top 10% of the picture and placed it at the bottom. Red does seem to be there, although slightly weak. If the LCD inside is a RGB setup, I guess the Red and Green layers are aligned, and Blue is off. Hope the extra info helps! everyting is working good but it has ghosting image problem
    Sergeant:
  • 399 Answers
Its the problem of convergence in your device.still try to reset the device by removing all the connections and reinserting firmly and properly at proper places and proper position.and then on the unit.also try disconnecting the dvd and reconnecting the dvd.
thanks.
Posted on Sep 21, 2008
  • masterexpert Sep 21, 2008
    just click this link the page will open and you yourself can do this problem solve with complete diagrams with complete instructions ,with what tools you require to solve this problem.
    it contains the diagrams which are not been able to copy so you have to click the link and the link will just open in 2minites just follow the instruction .
    http://home.earthlink.net/~oleg.filippov...
    the same problem what u have given in yours that exact same problems solution is given it very easy.
    it will not cost u more then 15$ to solve your problem with parts.
    as how to do what to do all is given.
    feel free for further queries.
    thanks.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Blue stain on the image projected by my PLV-Z3
I had the exact same problem with my z3, Turnes out it was the blue filter.
I used the full service manual, and managed to fix mine using the diagrams, and troubleshooting section.
You can get the full service manual here.
http://yama.co.za/forum/index.php?topic=147.0
Apr 05, 2008 | Sanyo PLV-Z3 Multimedia Projector
Ghosting image
Hi there
I'll bet you any money that the problem is cable related.
We often get this problem and by swopping the cables we normally get the problem solved.
Hope this is of help
Mar 26, 2008 | Sanyo PLC XU30 Multimedia Projector
EZPRO 610H...has a red shadow
this is ghosting, caused by interferance. cheaper cables tend not to have metal sheathing and those ferrite RF suppression thingees on the ends, which prevents this problem.
also, avoid running your signal cables next to power cables. If your cables are long (say more than 10m) this may also cause problems.
Nov 22, 2007 | CTX Optoma EzPro 610H Multimedia Projector
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Philips ProScreen 4750 Impact Multimedia Projector Logo
560 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
