Question about Uniden Cordless Phone
Phone connections I live alone and I need to connect my phone wires to the outside box. I don't no where to connect the wires. Can you help me?
  • Carl Navarro
    Carl Navarro May 11, 2010
    Unless you live in a shack, the wires already should run inside from the outside box. You ought to be able to locate an outlet or two that has a modular jack to plug in your phone. If not, see if you can get a neighbor to help you.
    New Friend:
  • 161 Answers
I wouldnt attempt to do it yourself because if the phone just so happens to ring while you are touching wires you get get zapped pretty bad. call in a pro to do this.
Posted on Sep 30, 2008
What is the ground & neutral wire for a JPK15 GE Oven?
Assuming this is in the USA there are 3 wires normally in a 240 volt circuit. A black, red and white. Sometimes there is a bare ground wire. The white wire and bare ground wire are basically the same.They connect to the same place in the electrical box. The red and black are your power wires. They would connect top the outside connectors and the white and bare wire (if supplied) would connect to the center connector.
Mar 22, 2015 | GE JKP15 Electric Single Oven
How do I open the ports for mysql on my router. I have a database box and a development box and need to be able to have the development box be able to access mysql on the database box via the standard...
hi,
if you are wired as described there are no ports to open on your router. you are in the same vlan(IE:192.168.0.1/254) so no port routing is needed unless you are accessing them from the outside world which is what your router seperates you from.
however that means the systems can in theory talk to each other but you are now onto firewall rules of each system. effectivley only the mysql server need alllow inbound as outbound is usually not blocked. you can test if you are having a port issue by opening a command prompt and type telnet server_host 3306 (where server host is the ip or name of the server ) If you get a connection and some garbage characters, the port is open, If telnet hangs or the connection is refused, the port is blocked,
all that being said I would recommed you close any ports from the outside that don't absolutly need to be open.
GL
Hope this helps
please don't forget to give me a rating
Thanks
Jammer
Sep 19, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
How to hook up a telephone. I need to know how to hook up a telephone from the box outside to the phone jack inside.
In order to do that you need to know on which pair does your phone jack inside your home is connected. In case you don't know or it is not connected then you need drop wire and punching tool to connect. Simply ask your service provider on which pair he has connected connect the drop wire on the same pair and extend it to your phone jack with drop wire.
Jun 30, 2011 | Lands Phones
I can't figure out how to set up a voicemail or answering machine
The phone doesn't have an answering system built-in. If you use a voicemail service, you will need to check with the provider for the phone number and then follow their directions to set up your mailbox. If you are connecting a stand-alone answering machine, you will need to daisy chain the devices. Connect the phone cord from the wall jack to the answering machine IN port. Then use another phone cord from the answering machine OUT to the CL2909 TEL port. (If you are using a fax modem (or regular modem), with an anwering machine feature on your computer, then you still want to use this chain method. The data port may not let the computer answer a voice call.)
If you are using a free standing answering machine, after connecting everything together, make sure that you hear a dial tone and can properly make calls. If you do not get a dial tone, replace cables. (I recommend you check that the phone works by plugging it directly to the wall jack before doing a daisy chain of devices.) Turn on the answering machine and set the outgoing message and number of rings as per the directions for the answering machine.
If you have any problems, make sure that the line is good. I use an old rotary phone to check my service connection (at the box since that has RJ-11 connections in my home). You may want your phone company to check if the line is good to your home if the service doesn't have RJ-11 connections. If the problem is in the wiring, check the jacks (loose wire/broken wire) and exposed wiring (missing insulation/breaks). You may need a professional to check in the walls; your telephone service provider will fix this for a fee. If the problem is outside, then the provider will fix it free.
You can get the manual and guick start guide as PDF files from AT&T: http://telephones.att.com/att/index.cfm/product-detail/?ProductID=290 . The links are on the right hand side of the page.
I hope this helps.
Feb 07, 2011 | AT&T CL2909 1-Line Corded Phone
My phone says parallel set on how i fix it
I assume you cannot get dial tone on your Vtech handsets or base unit. The phone is telling you that another phone or device has seized the line, therefore it cannot give you dialtone. You could have another phone or device(fax, modem, etc.) off hook or you could have trouble on the line caused by bad wiring, faulty line cord, or bad outlets. To find the trouble, you need to remove all devices from all outlets and try to isolate the bad wiring, line cord or outlet by connecting a standard good phone to one outlet at a time using a known good line cord. If you are unable to isolate the trouble using this method, try going to the outside interface box and testing the line there. Inside the outside interface box there is normally a test jack with a short line cord plugged into it, unplug the test jack and plug your standard phone into the test jack. If you don't get good dialtone then the trouble is with the service provider and you need to report it to your service provider. If you do get good dial tone then the trouble is in the building wiring, outlets or phone devices. Typically there is more than one pair of feed wires from the interface box to the building outlets. Remove all but one pair, then go inside and check all outlets for dialtone(plug standard phone into each outlet one at a time) to find which are connected to the pair of wires that are still connected at the interface box. If you find trouble on this feed wire( can't get dialtone at any of the outlets), remove it at the interface box and connect a different pair of feed wires, go inside and test all outlets again. If a feed wire tests good(you get dialtone on at least one outlet) then do not remove that feed wire at the interface box and just add the next one at the connection terminals in the interface box then retest your outlets again. Work your way through all of the feed wires and outlets in this manner to isolate where the trouble is. A bad wire, line cord, outlet or phone can produce a short or partial short across the telephone wire pair that will appear to your Vtech phone as if a parallel set is in use. It can sometimes take quite an effort to locate a bad wire or outlet. Good luck.
Feb 02, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
My phone rings once and drops the caller before the second ring.
This is often caused by a partial short on the phone line, usually on the service provider network. If your land line enters the building through an outside interface box, then you can test to determine if the trouble is with the service provider or is in the building wiring, outlet, or telephone device. Inside the outside interface box there is a modular test jack with a short line cord plugged into it. Unplug the short line cord and plug a standard phone into the jack. Make a test call, if the problem still occurs then the trouble is with the service provider and you will need to report the trouble to them. If the trouble does not occur with the test phone plugged into the test jack, then the trouble is in your wiring, outlets or devices. Through a system of elimination you can discover where the fault is. Start by disconnecting all devices from outlets including the line cords. Connect one device to one outlet, make test call, if the touble is gone, then check each device one at a time to determine if one of your phones, fax machines, answer systems, or modems is bad. If the trouble continues with only one device connected, check each outlet visually for corrosion, escalate to removing the wiring connections at each outlet except for one. Make test call again to determine if trouble persists, if it does remove the wiring connections at that outlet and reconnect at another outlet, test again. With patience and persistence you can find the bad wire, outlet or device. In the outside interface box there may be more than one pair of wires connecting to your outlets. The process of elimination can be woked from this end also, by removing all but one pair of wires connecting the outlets and make a test call from inside after finding the connected outlet. Work your way through all the wiring to determine where the trouble is.
Feb 01, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have the westell 7500. I have DSL with Verizon. The connection keeps dropping since day 1. which was about 5 weeks ago. The tech has been out about 6 times , replacing lines outside . rewired my house....
if you given parallel connection to phone means u have to use one filter for phone and dsl . in that filter 3 plagin will there 1-line in,2-phone,3-dsl or mdem. give connection to 1-direct wire comming for outside, 3- dsl modem, use 2- give parallel connection. if u not done this means when u pick the phone connection will get dropped. still go to this page http://www.rajasthan.bsnl.co.in/main/trsh.htm or call me 9740575949 moz-screenshot.png
Feb 25, 2010 | Westell Wirespeed VersaLink...
I have 2 sets of wires in the outlet box, the outlet box is connected to a wall switch. Which wires do I connect to the fan.
Usually the two wires that go to the wall switch are used to break the load, (switch the power (COMMON) OFF and ON to the fan).
The other wires in the ceiling box are the supply wires.
You need to look at the wires and find the pair that are LIVE, the one set that has live power on the BLACK wire. This set of wires are the SUPPLY wires. You can use a voltage detector or a neon bulb tester to determine which wires are LIVE. Once you do that, you should turn off the breaker until you have finished the installation.
Connect with a wire nut, the Ceiling (SUPPLY) box WHITE (neutral) wire to the fan's WHITE wire.
Connect with a wire nut, the BLACK (common) SUPPLY wire in the outlet box, to the WHITE wire going to the switch box,
Now connect the the BLACK wire coming from the switch box to the Fan's black wire.
Be sure to connect the bare copper ground wires together with teh Green (or bare) wire from the fan, with a wire nut.
This completes the wiring of the circuit and the fan should go ON and OFF with the wall switch. Now turn on the breaker and check for proper operation.
You can change the speed of the fan with the pull chain on the fan, if this is a standard ceiling fan.
Hope you find this information Very Helpful and best regards!
Aug 23, 2009 | Dryers
2 wire has me seeing red
check that your telephone line (connection box) is all tight, check every junction box to insure all connections are tight.... THE OUTSIDE BOX IS also very important...
I also use lite sand paper to insure all the connections are bright-shiney before i re-connect.
Sep 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Snowy picture
You will need to know how to solder to fix, depending on the set, some have a stand alone tuner and others an onboard tuner and if it's stands alone then you can order a new tuner, but if it's onboard(meaning apart of the whole board) you have to resolder. Hope this helps! You will need to solder the thin wire inside to its broken part and the outside piece to its ground. and the two cant be touched or bridged.
Sep 13, 2007 | RCA 24F512T 24" TV
Uniden Cordless Phone Logo
23 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
