Question about Garmin StreetPilot C330 GPS Receiver
Wont turn on
I went to turn on my garmin, the screen momentarily came on, then went blank. it will not turn back on.
  • 1 more comment
  • southernsuds Sep 21, 2008
    I'm having the same exact problem. It started today.
  • vallen7 Sep 21, 2008
    Same problem. Screen came on briefly then went black. I cannot charge either by car plug or USB plug to computer.
  • Anonymous Sep 26, 2008
    was working fine. then the screen went blank it was plugged into lighter. I let it sit for 1 hour it came back on for a second went out
Question: Why won't my unit charge while plugged into my vehicle?
From the Garmin site: --> Answer: If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece. wont turn on - fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e53bea0-6874-11dd-436f-000000000000}&ext=jpg
  2. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  3. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 08/12/2008
Posted on Sep 28, 2008
Garmin Forerunner 210W screen is blank. No charging symbol appears when it is on the charger.
Not sure if this is useful but double check that your charger connection to the Garmin is actually clean. I've had to clean the contacts for both my 405 and my 610 in order to make sure there was a solid electrical connection. Have you tried resetting it?
Feb 20, 2014 | GPS
My garmin 210 just went to blank screen
saving activity is due to a voltage problem check your connections and don't leave it in the sun!
Sep 06, 2012 | Garmin Forerunner 210 - Unit Only
Nuvi 1300 squeal
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi won't turn on
See if you can find the reset button on the unit and push it while the unit is on. On newer units the reset button is on the back, but on older units it may have a faceplate cover around the edge of the screen you have to remove and the reset button is sometimes located under the faceplate...this may work
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Blank screen. Not working at all.
Try to turn it on while it is plugged into the charger and see if it works. if not, you might need to update your software using this website: www8.garmin.com/support/collection.jsp?product=010-00401-20
Oct 22, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C330
IS the battery charged fully? Try turning it on while its plugged in.
Oct 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
put your thumbnail under the silver faceplate above where it says garmin and on the right you will see a reset button. It will reset your garmin and you will not lose your information. Hope this helps.
Patti
Dec 12, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
