Question about Tools & Hardware - Others
Ryobi gas/oil mix trimmer rewinding the string
I would really like to know how to rewind the string on this thing. did it before but today I just could not seem to get it!
    President:
  • 1,723 Answers
Watch this little video and it will help:
http://www.youtube.com/watch?v=larH6qDrBp0
Posted on Sep 11, 2009
31cc 700r curved shaft string trimmer binding flywheel and cord rewind during reassembly
as you put it together, pull the handle a bit so the recoil starter fingers fit into the flywheel as they should
Aug 18, 2015 | Ryobi Garden
Starter cord has jammed
You will have to remove the starter rewind mechanism and rewind the cord around the pulley, then pre- load a certain amount of tension on the rewind spring.
Apr 17, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have a Ryobi gas click it system. Have been
You didn't list the model but those little rewinds are typically built very similarly.
It may sound a little crazy but it works, take the unit to a power washer such as a car wash and blow out the gook in the rewind with lots of hot soapy water and then rinse. Then using a probe or small screwdriver get the rewind unstuck. If it retracts you’re good to go if not let me know as you may have a broken piece in there
Jun 04, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I can pull my string from a ryobi cs 30 and it wont go back
Either the rewind spring is broken or the starting spool is stripped. Either way you have to open up the entire unit. Check those two things and good luck...Lee
Oct 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Apr 09, 2009 | Garden
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Tools & Hardware - Others Logo
738 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
