Question about Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher Did you fix your dishwasher? Mine is doing exactly what you posted yours was doing last month. Mark
It ended up being a bad Control Board (or panel) which had to be replaced.  I tried all of the other solutions online;  push this button twice, then that button 3 times --  sometimes its just easiest to call in the professionals.  I have a home warranty so it only cost me the service fee Good Luck!
Posted on Sep 26, 2008
My dishwasher is not draining
ists not draining.. meaning you dont hear the drain pump kick in? or if you do hear pump kick in, have you checked the hose to the drain..? it could be blocked with a build up of food over the use of dishwasher.
that happened to mine last month. it would fill, but seemd not to drain.. until i disassembled the dishwasher drain from the sink connection and saw at sink connection it wss blocked.. its an easy fix.. unscrew the clamp on drain hose and pull apart and push food back into the drain to wash it away.. good luck !!
Sep 27, 2014 | Kenmore Dishwasher With Ultra Wash And...
Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
Mar 18, 2012 | Samsung DMT300RFS Builtin Dishwasher
L65X Dishwasher problem
has there been a soultion mine is doing the same?
Jan 10, 2012 | Dishwashers
Newer dishwasher and actuaslly says in manual do not be alarmed if you cannot hear dishwasher as it is very quiet. Well mine is the exact opposite. It is so loud. Sounds like the motor is in overload....
I would suspect there is something stuck in either your wash motor or drain pump. If the noise happens throughout the whole cycle, it's likely the wash motor, but if it only happens on start up and periodically thoughtout the cycle, it's the drain pump. The drain pumps are known however to get noiser after a few months, in which case I would have the drain pump replaced.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My 5 month old LG dishwasher is making a high
Good day-
I am the proud owner of a LG LDF6920WW. I bought it 10-2008 and it developed a high pitched sqeel (HPS) exactly 2 years and 3 months later. It first occurred on a monday and repeated on the following Wednesday. After the water filled the machine and the swirling, pumping, cleaning cyale began, the HPS began and lasted until the drying cycle. I searched the internet and determined that this HPS was occurring anywhere from 5 days of being purchased, up until the 2 year mark. I was weary of believing that a motor would fail in a five day period as well as last for up to 2 years, so I "Googled" parts for my model and looked at the scematic or parts break down chart. Refering to the chart, I began to disasemble my dishwasher after removing it from the cabinet and taking it to the garage.
I focused on the sump assembly. I removed all parts, motors, baffles, bladders, check valves, etc. I thougroughly cleaned all pieces and parts with windex and a scotch/sponge. I removed all food and debris from all surfaces and gaskets. I cleaned the main body cover by using a low pressure hose and alternating cleaning the top and bottow. I made sure not to rip the micro screening. Upon re-assembly I used high heat, automotive bearing grease to lubricate the seals where motor shafts protruded through them. ****Important**** I set the clutch setting at 3 on my electric drill to screw the assembly back together. I also disassembled the water inlet valve and the float assembly on the left side, exterior of the dishwasher and cleaned that completely out. I flushed all hoses as well.
I put it back in, connected all water, electricity and back-flow devices. The dishwasher is once again silent. All motors and bearings seemed fine. During tear down, the only problems I found were: 1) A lot of debris in several places. 2) dry gasket to shaft surfaces.
Jan 19, 2010 | LG Dishwashers
Haier buttons not working!
From previous experience, I would bet that the circuit board/ control panel is failing. The one I had leaked steam near the top of the unit and the condensation will work it's way into the top control panel. Bad design on Haier's part. The worst part about mine was there is no adjustment for the door. I ended up getting a refund on the unit and buying a very nice LG model. Good luck dealing with Haier. They will send A&E factory Service out and they are not very good. I would suggest getting rid of the Haier. (personal opinion)
Jun 01, 2009 | Haier ESD400 Stainless Steel 24 in....
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
Candy cdi 1012 dishwasher
Did anyone ever manage to work out what the cause of this was? Our dishwasher is exactly the same. We had it fixed once under warranty and it lasted about a year before breaking again. Unfortunately we never asked what work was done during the first repair. Thanks. Stuart
Dec 20, 2008 | Candy DFI Plan Built-In Dishwasher
Kenmore Oasis HE Error Codes
I had the same problem with the computer dashboard at exactly the 6 month mark. Since then, one month later my washer has stopped filling with water. I have been without a washer and a dryer for a total of 3 months during the warranty period. Good luck on getting answers. I truely feel sorry for you.
Sep 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Rinse Aid does not dispense
http://www.partselect.com/ModelFrames.aspx?ModelID=149370&ModelNum=PDB2600AWX&mfgModelNum=&ManufactureID=1&Selected=54869&Position=1&mfg=Maytag&Type=&Mark=3
From diagram RINSE AID & SOAP DISPENSER, replace 138912t.jpg PS138912
Wax Motor for Detergent Cup Actuation.
Feb 20, 2007 | Maytag 24 in. MDB4100 Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
