Question about Technics Audio Players & Recorders
I have a Technics SL-MC7 multiple CD changer that my dad unknowingly moved with CDs in it. I can't get the door open now - how can I fix it?
  • craigs746 Sep 21, 2008
    I got it! I opened the top of the case and was able to get all of my CDs out of the player. Then made sure it worked correctly before putting the case back on - all fixed. But thank you to those of you who attempted to sovle my problem.
    I got it - I was able to fix my problem by opening the case and getting the CDs out.
    President:
  • 1,263 Answers
The quickest way to do this if your comfortable with opening electyron componants is to take the top of the unit off. there will be a cover over the disk carousel that has to be removed as well you will be able to remove the disks from there and then replace everything back in the same order. becareful not to wear clothing that will hold a static charge, a discharge on the circuit boards will fry them. also do not touch the optic glass of the laser this will damage it. please rate the solution...thanks
Posted on Sep 21, 2008
  • 2,071 Answers
First you do is to reset the unit,just unplug the unit for 3 - 4 hours and re plug again.If nothing happens then that is the time you open the receivers.The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. If the disc starts to spin slowly and doesn?t come up to speed, the spindle motor that?s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you?re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak. Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved. Hope this may help; Regards, VOTIT
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
there is a tiny hole that you can use the pin or
needle to make open!!!
to open the tray like in the dvd room
  • 10,594 Answers
That's great, you did wonderful job.
Have nice day!
Stuck in "checking discs" mode
Obviously your device is not working and you should seek professonal assistance..
Jun 08, 2015 | Technics SL-MC7 110-Disc CD Changer
The cd changer buttons do not work
Could be a broken drive belt. Sounds like the same symptoms that mine exhibited. You will need to open it up carefully, so you don't dislodge any CDs. See previous posts here for the exact size o-ring that you can find at your local hardware store as a replacement.
Aug 03, 2014 | Technics SL-MC7 110-Disc CD Changer
Reads all the cd but only plays the single cd everytime
This sound like a mode setting problem. Can you manually select another of the discs and it plays?
Dec 10, 2012 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
My Technics SL-MC7 was zapped by a power surge. I am looking for a power supply. The part number on the PS is CMKS-P3X but when I search it I get hits for a copier PS that does not look like the one I...
You will need a service manual to get the correct part number. Go online to Technics, contact customer support and technical department to see if they can provide one.
Apr 07, 2012 | Technics SL-MC7 110-Disc CD Changer
Looking for a drive belt for a SL MC300 Technics 110 CD changer
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
CD CHANGER BROKE
Have the same problem only mine does it on all slots. It appears the finger which removes the disk from the tray does not slide foward to "pick" the disk. Don't know why, tried to pull it and it will not move foward I was hoping this sight might have some sort of exploded view of the linkages but doesn't.
Jul 28, 2007 | Technics SL-MC7 110-Disc CD Changer
158 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
