Question about Mitsubishi WS-65611 65" Rear Projection Television
Need manual some times the blue color pulls away from the picture and we have to tap on the tv until the tv warms up do you know how i could fix this?
  • Mitsubishi Master
  • 8,617 Answers
Sounds like the convergence Ics need to be resolderd thats a common problem with that model mitsubishi.
Posted on Sep 21, 2008
There is blue and yellow shadows on our tv, any ideas what could be wrong? when there is any lettering on the tv shows, there is the same words under neath the others in a different color, we have had the...
Model indicated uses two of the STK-392-570 chips for convergence which is what you are talking about. See typical attached photos of this kind of problem.
Parts cost on EBAY would be under 20 DOLLARS and this can be a do it yourself repair.
I have start to finish, step by step instructions for this repair in this set--tell you everything you will need and exactly how to do it.
With a email address I can send you the instructions and if you or someone there has the skill you can fix it yourself.
Comment if questions or want the instructions--I follow up when I help people.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 14, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Covergence problems or alingment , its has three colors without alingment please help me!!!
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Apr 29, 2010 | Zenith R57W46 57" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
My rca F27668 tv fell down and the color is off its purple and blue yellow and green in diffrent areas. how do i fix this?
You need to degauss the TV,
This can be accomplished 2 easy ways i knwo of.
1.> If you have or know someone who has an old style soldering gun, the kind that has a pull lever and looks like a gun and buzzes when pushed, this will act like a degauss wand, simply plug it in pull the trigger and wave an inch or so around the affected areas untill the problem goes away.
2.> call a tv repair shop and ask them how much to "degauss" your tv.
Sep 25, 2009 | RCA F27668 TV
Color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Jul 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Dark fuzzy picture when tv is first turned on
I am having a similar issue. Did you ever figure out the problem??
Feb 29, 2008 | Televison & Video
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
Jul 31, 2007 | Sony KP-57WV600 57" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
