Hard drive is not showing up. - Computers & Internet
  • 781 Answers
Internal hdd.
a. check:
1. ide cable/sata cable is properly seated.
2. your jumper configuration is correct (slave, single, cableselect)
3. your power cable is properly seated in the back of the harddrive.
external hdd.
b. check
1. your firewire/usb connection is properly plugged.
2. your power cable for the hdd is connected and the enclosure power switch is on.
Posted on Sep 21, 2008
After install window not show may hard drive
Right-Click "Computer", Manage, Storage/Disk Management. What you see here is what you have, or at least what Windows thinks is connected. If you have a missing hard drive, check your hard drive connections.
Jun 26, 2014 | Computers & Internet
I am using segate u series ST340810 hard disk. when I am formatting this hard disk this hard disk does not shows partition to format and shows messege of disk cannot access what should I do?
Hello Ravindr,
After connecting the Segate Hard Drive in your computer go to Control Panel. In Control Panel you will the option Administrative Tool. In Administrative Tool open the Computer Management and you will find the number of attached Hard Drive and the Partitions they have. If the Hard Drive you have attached is not showing the partition then there may some physical damage with the Hard Drive media. Please get your Hard Drive checked by Segate professionals and then replace the Hard Drive with new one.
Jun 03, 2011 | Seagate U Series (ST340810) 40.02 GB Hard...
Lacie 1tb only showing n 30g room
Hey there,
A hard drive, especially a new one, might need to be formatted before use to show the proper amount of data available for use. Sometimes a hard drive might malfunction and not show the proper amount of free space. formatting should also solve this problem, Before you go and format your hard drive understand that by formatting it you will lose all data that is stored on it, so if you have anything important, take it off first.
here is a detailed guide to reformatting your hard drive based on your operating system
http://thelightroomlab.com/2009/01/formatting-an-external-hard-drive/
Hope this helps!!
Mar 16, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My external hard disk is not working properly. i can see the icon in drivers and printers but there is no folderor icon to open
Please remove the usb cable and try to connect do you see the notification new hardware found if yes just check my computer dose the hard drive shows over there if yes and double click on it dose it open if yes and the hard drive is empty .
then go back right click on the hard drive check properties dose it show the empty and the full graphs if it shows full and dosnt show the drive letter.
then right click on the my computer icon on the desktop go to manage and diskmanage ment check the hard drive over ther dose it show its unformated or un initialized if no dose it have drive letter on it if no then right click on the drive and say change drive letter and assigned one letter like h or g and check in my computer now dose it appair.if still so try changing the usb cable may its defective.
if dosent detect at all could be your hard drive case so you can remove the hard drive from inside the case and connect it directly.in the computer if works backup your data abd return backthe hard drive in the case and if its still in gurentee return it to the service center.
Dec 14, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Not able to transfer file onto the external hard drive
IBM 40 GB usb HDD When plug in then Drive icon show but data can not show. Drive properties shows 0.0 Mb
Dec 08, 2009 | Western Digital My Book Home Edition 500...
My external hard is connected through usb but it was showing connected but my hard drive does not show any drives how to solve my problem
first of all u can right click on the my computer then mange disk managment and then see ur hard drive is present or not if their is present and go to 2nd hard drive and then righclik the hard drive and create a new partion
Aug 28, 2009 | Fujitsu (MHV2120AH) 120 GB Hard Drive
WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
Aug 11, 2009 | Western Digital WD Passport 250GB Portable...
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Hard drive wont show up
change the jumpers to slave if it is on the same cable as the master should show up
if it is set now on master it wont show up
Feb 23, 2009 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
