Do not know how to replace ink jet cartridge - Office Equipment & Supplies
  • ben9 Sep 21, 2008
    Your info was excallent thank you Ben
  • 174 Answers
Your printer may have a button that when you press it,it will slide the ink-jet cartridge.
open your printer cover and gently remove your old cartridge from your printer.
careful not to spill toner as you move the cartridge.A
Posted on Sep 21, 2008
Open panel above printer paper cartridge should move to the middle pull towards you and replace old with new one the same way old one came out
Why will my Epson wf7620 not print black ink after replacing the cartridge?
Hi. I don't know if your printer is new or old or if this was the first time you replaced the cartridge or this has occurred after several changes. Most if not all printers will have this occur after replacing a cartridge if the ink had been depleted for some time and allowed to dry up in the jets. Sometimes all it takes is a day for this to happen. I have found that I must go through several cleaning cycles to clear the clogged jet(s). So, try doing a few cleaning cycles and see if that solves the problem. Another cause for a printer not printing after replacing a cartridge is surprisingly a FAULTY or remanufactured cartridge. There should be a program on your computer that displays the cartridge condition, cleaning procedure and ink levels. Give that a look over.
Feb 20, 2015 | Epson WorkForce WF-7620 Wireless Color...
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
I want to know what is inside the printer cartridge
The ink cartridge are of different type and contains ink in different form.
  • Thermal Ink jet Cartridge (HP, Canon) - The cartridge contains a liquid ink, which is heated by a heating plate on the cartridge. A bubble is formed which forces the ink which comes out of the nozzle.
  • Piezoelectric Cartridge (Epson) - The cartridge contains piezoelectric crystal, which when current is applied changes shape and size forcing ink out from the nozzle.
  • Toner (Laser Jet Printer) - A drum contains powdered ink (toner), which is spreads on the paper using negative and positive charges and the heater sticks the ink on the paper.
Regards,
Shrey
Jun 07, 2011 | Computers & Internet
My printer is printing blank pages.
Either:
* empty ink cartridges
* clogged ink-jets, such that no ink can be sprayed onto the paper
Use the HP software to check the ink-levels in the cartridges.
Run a few "print-head-cleaning" cycles. If still no output, then replace the ink-cartridge(s).
Feb 22, 2011 | HP J4680 Office Jet All-In-One Printer
My printer isn't printing from the black ink cartridge -only color. I've replaced the black ink cartridge twice, so I know it isn't the cartridge.
Run a few "print-head-cleaning-cycles", to UNCLOG the ink-jets that should be spraying the black ink onto the paper.
Feb 21, 2011 | HP DeskJet 3740 InkJet Printer
Black ink will not print text
maybe the ink jet cartridge is depleted. This is common on all ink jet printers.
Or, the ink jet cartridge has tape on the head.
Jul 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
It says used ink jet full. I don't know what that means. All of my color ink jets are full and I can't even make them come forward to check them but I'm sure they are full. What is the used ink jet.
Used ink jet is probably something like the 'waste toner' cartridge in laser printers. Look in the manual for a reservoir that has waste ink somewhere. Hopefully it'snot in the ink jet cartridge.
What year,make,model printer is this for further research?
Jul 02, 2010 | Office Equipment & Supplies
Ink cartridges
The symtoms of a dried out cartridge is white lines through the printed letters.
I've seen brand new dried out cartridges.
Aug 08, 2008 | HP DeskJet 882c InkJet Printer
Nukote Black Ink Jet Replaces HP21
clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
Problem with Dell ink jet refill....
Are you using the Dell software to replace the cartridge?
If you where just replacing without running the software then it wont know you have replaced the cartridge.
Let me know.
Zod
Apr 24, 2008 | Dell 924 All-in-One InkJet Printer
99 people viewed this question
jasbo
jasbo
