SOURCE: HELP MY VSX 1015TX PIONEER
Try pressing the ENTER + VIDEO2 buttons on the front panel of the unit for 2 seconds. The unit should then come back to life and MCACC should go off.
SOURCE: plugged in no power
the connecting pins have been flattened slightly by putting the plug on and off. i GENTLY squeezed the pins in an upward direction so they would make a better connection.
remember to be gently. when you fix this. do not dismantle the charger again.
SOURCE: HP Deskjet 9800 will not power up.
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
SOURCE: won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
