I have a Bosch 16B hot water service that won't light. I have replaced the batteries and checked there is gas working in the rest of the house. Is there any thing else I can do to make this work
co7196
  • 3433 Answers
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Posted on May 06, 2009
rockitman187
  • 2559 Answers
SOURCE: Bosch TF250 hot water service
Replace the flame sensor.
Posted on May 11, 2009
motor1258
  • 6674 Answers
SOURCE: hot water comes out lukewarm
Pop out center of handle, and remove the screw from center, and remove handle. There should be a little nylon gear like sleeve that will pull out from center. Pull it out, and rotate it one way or the other, a little at a time, and slide it back in. Now just slide your handle on long enough to try it, no need to attach with screw yet until your done. May take a few tries to get it where you want it, then simply put handle back on, secure it with the screw, and snap cap back over screw.
Posted on Jan 06, 2010
dcramer531
  • 1654 Answers
SOURCE: Hi There, We are in a
You may have a dirty pilot orifice. Try this. Turn off the pilot by turning the control knob to off. Remove the front panel to get access to the pilot orifice. Use a can of compressed air with attached straw (the same stuff you use to clean computer keyboards) and blow out the pilot orifice, which is inside the pilot assembly where the pilot flame burns. Blow it out from the top and from the sides through the air holes. Then relight the pilot and see if that improves the flame size and color (blue) to heat the thermocouple.
Here is a link to the manual and instructions. www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125B_manual.pdf
Posted on Mar 23, 2011
SOURCE: I have a Bosch Water
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Before calling service technician, read manual for fault finding and possible solutions.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdf
http://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdf
Following links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_going
http://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keeps
http://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water
1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspx
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#
3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Add a comment with your experience so others with same-similar problem can benefit.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 03, 2011
I have a bosch aquasar 125b tankless water heater and the burners do not light when hot water is turned on this also causes the pilot light to go out
possible faulty pressure switch connected to the water line and that is failing to turn on the main gas tap solenoid
best have it checked by an accredited gas fitter or service center for the make
Aug 20, 2016 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Water not as hot as it was.
Tankless require yearly service to keep burner and combustion parts clean and check electrical connections, gas solenoid, gas pressure, venting, etc.
Read product manual for advisories and recommended maintenance.
Yes, aren't you glad you saved the manual.
Always check that local area has affordable and qualified service technician for your brand before buying tankless.
Before calling service technician, copy following link for general troubleshoot resources, including some manuals, and links to Bosch.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Try turning temperature down.
The fact there is no error code, and the gas is not firing correctly, means you have a small unit with no error codes and PC board has failed ... or it means you have a unit with error codes and possibly bad PC board.
If problem is the PC board, then Bosch will send you new board, and expect same level of repair success as though your computer's motherboard was replaced.
You can buy ordinary box-store tank-type heater and install yourself same day for about $325.
Then maintain and fix it yourself. I recommend AO Smith/American/State/Reliance/Kenmore/Whirlpool since these are easy to maintain with clear directions in manual, plus AO Smith posts service manuals for the whole line of products, and any local plumber can fix them with ez-to-locate generic parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 07, 2012 | Bosch & Tankless Water Heater
Will not fire at all, trys to light but get the e1 code . used to work intermitently or fire right of way but then go cold and back to hot for about five min. then stay hot now wont even light
Before calling service technician, open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Bosch_E1_troubleshooting.pdf
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
http://waterheatertimer.org/Crossover.html
Before installing tankless water heater, read the service manuals and product manual to make sure you have testing skills and equipment needed to repair tankless gas water heater, and that you are prepared to buy expensive parts when needed and do the recommended yearly and monthly maintenance as outlined in manual.
Also check that area has qualified service technician, and that person carries parts on-hand, and is certified for your model number. Keep Tankless manufacturer contact information on-hand, and be skeptical of promises of unlimited hot water, and effortless long-lasting water heating, and saving money. The only folks saying this are the folks selling the product, and not their customers.
Fix most tankless gas water heaters yourself, same day, all brads for about $350.
Sep 21, 2011 | Bosch Water Heaters AquaStar 250SXO...
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Bosch Water Wizard 10P - have no hot water, no water comes out the hot water tap, can't light Pilot Light, not sure where to start would love a step by step diagram how to start pilot light -...
Apr 03, 2011 | Bosch & Tankless LP Hot Water Heater
Cannot get the pilot light to start on a bosch instaneous hot water service
Check that you have power to the unit or that the battery inside the unit isn't dead.
Also check that you have gas at the unit
Hope this helps, if not I'll need more info like Model, age of unit & location e.g. inside - outside etc.
Mar 06, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch instantaneous gas hot water not working. sounds to be sparking but not lighting and heating water. The gas is turned on. Just moved into this house so new to the machine with no manual. Comes up with...
Feb 14, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch water wizard 16 - gas still runs after water tap turned off
Sounds like a flow sensor may be bad. It may be registering flow when there is none and it sending signal to ignitor and gas solenoid that there is.
Apr 04, 2017 | Bosch Water Heaters
BOSCH TWH-G1-25 not lighting
Model????? The 635Es, 250SX and 2400E are same. The 2400ES and 2700ES are World 2 heaters. Any error codes as I can't imagine this problem w/o codes. Flow initiated but you have spark. Is there any ignition? If so flame rod may be bad and not reporting ignition. Igniter sets on some early 2400/2700 have proved to be bad. Water pressure has zero to do with this. If you have an EC or EA code you have gas problems (meter, line size/length or gas valve). Also if 3005 or 3007 Software you can pull the last 5-10 error codes from Controller.
You need to call Bosch and get an RSA out there. This is a gas appliance that if you screw up can destroy your house. FYI any water in the gas valve condemns it. It will not dry out and work correctly. Is the fan running at ignition and/or purge? Any Controller errors require replacement. You have 2 years on parts warranty from installation date so don't screw around trying to DIY. Warranty Labor is not covered.
Flue obstruction? If you used the AQ3 installation Kit you have the wrong termination box to prevent freeze up and/or water penetration You need the Z-Vent drop nosed termination. Look for a fine tan dust in the fan intake (brown plastic) the intake throat or in passageway to the gas valve. Call Bosch unless you're a Gas Tech this is beyond you.
Mar 02, 2009 | Bosch AquaStar 2400ES-NG
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
