Question about Craftsman 24 Hp 48" Deck Yard Tractor
Transmission won't engage
My Crafsman FS 5500 24 Hp Intec starts up fine and stays running but will not go forward or reverse. However the cutting deck engages and works fine. What is wrong?
Jim
  • 2 more comments
  • Anonymous Nov 03, 2008
    mower will engage - deck raises and drops ... transmission won't engage ...
  • kcg818 Dec 07, 2008
    Sounds like the same problem my wife and son have experianced today.I look forward to arriving home and research the solution,but welcome any info. availiable at this time.Scott
  • Anonymous May 09, 2009
    craftman lawn tractor will not move in gear
  • Anonymous May 22, 2009
    When I try to move forward, I get a grindind noise and the tractor moves slugishly
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Posted on Oct 12, 2008
I had this happen and found the Transit Position had been changed. The lever at the rear is where I found the problem. Once I moved it to the other position it worked. That might be what happened.
Posted on Feb 05, 2009
Model dgs6500. Why does it cut off when I push reverse pedal?
is it cutting out in reverse when the cutters are engaged??
some will do this as its a safety device, more modern machines have a over ride, be it on the ignition swith or a button or even a pedal
Apr 11, 2016 | Craftsman Garden
Kubota T1570 transmission will not engage in forward or reverse. Starts fine and runs fine, mower blades engage, but no movement. Worked yesterday, not working today. Any ideas? Thank you.
Only problems that come to mind are rather obvious ones. My first guess would be a broken HST belt- the one from the engine to transmission- OR part of that belt assembly (idler pulley, slipped off a pulley, broken tension spring). Another possibility would be the pedal linkage. Maybe a pin fell out of that somewhere and the linkage isn't engaging the transmission.
Oct 27, 2013 | Kubota Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
96 ROVER DISC. Has strong reverse - won't engage any forward gears. Fluid seems full even when warm.
Make sure the 4wd shifter is in correct position and hasn't slipped out of correct spot to get you moving forward.
Mar 27, 2013 | 1995 Land Rover Discovery
1999 FORD EXPERDITION TRANSMISSION WON'T MOVE FORWARD BUT MY REVERSE WORKS FINE WHAT I NEED TO DO
You can try shifting into manual 1 to get moving then once you get going shift the lever up into Drive. This should work, then drive it to a shop to have your ****** looked at.
Feb 08, 2012 | 1999 Ford Expedition
Changed starter and now transmission won't engage in reverse. What happened?
is the level of fluid ok ? im afraid your transmission went bad not because of the starter change but it just happen at that time
Jan 10, 2012 | 2003 Kia Sedona
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
WHEN YOU PUT THE CAR IN DRIVE IT WILL NOT GO ANYWHERE
Its the electronic shift control located just under the battery ontop the transmission replace or repair will solve the issue
it'll go into drive but once it reaches 1500 rpm it'll drop into neutral as a safety because at this rpm it is being told to shift gear and when it fails to do so it safely goes into neutral
it will go into reverse just fine and park and you can run all the low drive gears until you reach 1500 rpm then it'll cut it off
i pulled mine out re soldered bad components on the board to fix it but im an electronics engineer it may be easier for you to just replace it
Aug 09, 2009 | 1995 Dodge Avenger
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
1,460 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
