Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage opener wont work
Green light on back of opener flasher and hear a clicking sound, im trying to find out how to adjust the stop both in the open position and closed. seems the screws on the side and back of the opener have been adjusted improperly and dont know how to tell for sure
    Problem Solver:
  • 7 Answers
What model and or type
Posted on Sep 25, 2008
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
How do I fix my garage door opener? May have moved sensors. Door will not open or close. Tried to align the sensors but don't know if they are aligned or not. When I push the wall button I hear 2 clic
on mine i have one red one green just the same keep trying to adjust the blinker or both till it is solid color check wires on back of it also.
Jan 17, 2015 | Building Materials
I have a 41A5483 chamberlain liftmaster garage door opener. At very random intervals it simply stops working, the unit light goes out and as I press the remote or wall button You can hear two clicks that...
first make sure there is nothing blocking the eye beams on eack side of the floor. like bugs spiders cob webs all can trigger it. wiggle them and make sure the eyes line up so that you receive a green light, if all ok try this, get a ladder and on the back side there is adjustment screw try to adjust the up and down pressure.
Mar 23, 2010 | liftmaster Chamberlain Garage Door Opener...
All of a sudden our garage door stopped working and the light flashes 10 times. Liftmaster Model 2265 1/2HP. Any ideas?
We just had the same problem this morning (cold weather can mess these things up). Not sure what you mean by "not working". Ours would open part-way and then stop (or close part-way and then stop), but could open/close all the way if we held the button on the wall down the entire time it was lifting. After much research online, we ended up checking the sensors at the bottom of the garage door tracks to make sure that the green light was solid (not flashing). Ours flashed a bit, so we cleaned the "eye" and tightened it in place. Once the green was solid, we thought we were done, but still had the problem.
Then we began adjusting the screws on the unit itself that show pictures of the door opening and closing. We thought we were adjusting the torque in the unit (because we read online that cold weather can make it more difficult for the motor to work), but in reality we were adjusting the opening and closing "distance". Apparently cold weather can also do something to the tracks, which can require adjustments to be made. Something to do with ground swelling...
Anyway, we also discovered that when we had closed the door manually (red pull-cord) the night before for lack of a better solution, it never properly locked back into position, which was adding to the problem.
So, first, try cleaning the sensors. You need a solid green light for them to function properly. Second, if you have used the manual cord, make sure the arm that it attaches to is locked back into position. You can accomplish this by pulling the manual cord, manually closing the garage, and then pushing the button on the wall. The door arm should lock into place. Third, try using a screwdriver to adjust the open/close distance. Start with a 1/4 turn for each position, and play with it until you find the right setting.
If these suggestions don't address your problem, this link worked for us...http://forum.doityourself.com/doors-windows/368278-garage-door-wont-go-down-cold-weather.html
Oct 10, 2009 | Electrical Supplies
Lift-Master garage door opener stopped working
The motor will probably need rewinding.
Professional job. Don't forget to take the condensor with the motor.
Or alternatively, if money isn't a problem,, get somebody out to look at it.
There ya go:)
Jul 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 1995 Sear garage door opener that stopped working
The trolley (the part that moves back and forth and is connected to your door) of your opener is most likely jammed against the bolt just in front of the motor unit. You can remove the bolt or loosen the chain until your unit will run. Once the door is closed find the 'up limit' on the side of the motor unit and turn it about 3 turns in the opposite direction of the arrow printed on the cover. Now replace the bolt or tighten the chain. Whichever you first did.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Opener wont open makes clicking noise
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Jun 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
67 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
