Question about HP Office Equipment & Supplies
I have a hp officejet 4315v all in one printer,scanner,fax and copier and I dont know how to set it up as far as wear what fone lines go wear....please help
Connect phone line from wall to Line 1 in port - looking at machine from back, the port furthest to the right - then if you want to also have a telephone on the same line, run a second phone cable from the phone to the EXT port on the back of the machine - that 's the one immediately to the left of the Line 1 in port.
Posted on Nov 17, 2009
Connecting my HP Officejet 4315v All-in-One Printer.Fax.Scanner.Copier with a phone modem in order to use the fax machine
The power cable goes in the socket on the far left. The phone line goes into the port named 1-LINE and runs to the wall. 2-EXT is for you to connect you phone or fax machine if you so wish.
If it is your first time installing the printer I would take a moment to go through the setup as mentioned in the manual here. It seem the USB port should be connected at a specific point during installation.
Hope this helps.
Sep 14, 2012 | HP Officejet 4315v All-In-One InkJet...
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
4315v Officejet all in one not faxing
Perhaps it is not connected to the phone line? Maybe you don't have a fax number set up? If your phone is having issues, it will affect this.
Apr 20, 2010 | HP Officejet 4315v All-In-One InkJet...
Hp officejet 4315V scanner will not install with windows vista
Try to scan from paint.....
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Mar 14, 2010 | HP Officejet 4315v All-In-One InkJet...
I want the softwear to install my hp officejet 4315v all in one printer.fax.scanner. copier.
If you dont have it, get it at HP.com/support. Search your model number to find the software.
a
Oct 04, 2009 | HP Officejet 4315v All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
I do not know how to scan,or set up my hp 4315v all-in-one printer. Can you help me?
Click on "control panel" on your computer, click on "printers and faxes", click on "install printer" (left of screen on my program). Then the installation Wizard should come up and follow its instructions.
Whether or not you have to go to "scanners" (same page as "printers and faxes") I'm not sure. Do the first steps I have listed for a start and if scanner doesnt work use scanner wizard. Hope that helps. Good luck.
Apr 04, 2009 | HP Officejet 4315 All-in-One Printer
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
67 people viewed this question
Seeker5211
Seeker5211
