I am trying to install Calendar Creator and it is telling me,because I have Vista, it cannot install Amjuni Document Converter 2.10 Kernal Mode print drive.
    Sergeant:
  • 300 Answers
The printer driver must be converted to user mode
This link contains information about converting the printer driver
http://unixwiz.net/techtips/win32-pdriver-ktou.html
You may ask for farther assistance in this matter.
Thank you for choosing FixYa!
Az.
Posted on Sep 21, 2008
Calendar creator deluxe windows 8
Calendar Creator is not supported for Windows 8 at this time. Even the newest version which is 12 is not supported fo Windows 8. You could try running it in compatability mode however.
Right click the Icon and select "troubleshoot compatability"
Hope this helps!
Jan 19, 2014 | Broderbund Calendar Creator Deluxe 10 Full...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
How to remove calendar creator 12 from Windows Vista
  • The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
    1. Start-->Control Panel-->Add/Remove Programs.
    2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
    3. Follow the panel wizard and reboot your PC when it finished.
    In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
    Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
    A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
    1. Free download Perfect Uninstaller form its official website.
    2. Install Perfect Uninstaller on your computer
    3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
    4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
    It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
    Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
    Under Creative Commons License: Attribution
  • Feb 03, 2011 | Broderbund Calendar Creator 12 for PC
    Hi Name is Joe.
    Resolution
    Installing on a Windows Vista computer
    Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
    Installing on a Windows 7 computer
    The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
    1. Right-click on the setup package and choose Properties.
    2. Click on the Compatibility tab in the Properties window.
    3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
    4. Click OK to save the changes.
    5. Re-run Creator 2010 the setup package.
    May 04, 2010 | Roxio Creator 2010 Full Version for PC...
    Would like to print to a pdf
    You should first install a pdf writer software like Pdf Creator. it is free.
    http://sourceforge.net/projects/pdfcreator/
    Install it and then when you are printing in a program like Word, select the Pdf Creator as your printer. Click on Print button and it will create your pdf document. There might still need some minor adjustments inside the pdf creator program but it works very well, no doubt.
    Mar 02, 2010 | HP PSC 950 All-In-One InkJet Printer
    Will Calendar Creator 12 work with Windows 7 64-bit OS?
    Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
    Jan 19, 2010 | Broderbund Calendar Creator 12 for PC
    Am trying to install Broderbund Calendar Creator Deluxe 12 on my HP pavilion lap running Windows XP. Problem is first disk tells me an older version of Calendar Creator must be removed before ver. 12 can...
    Usually in this situation when you loadup the new version it usually says what you are saying then goes on to ask if you want it uninstalled, you click yes, it then removes, you then usually restart and new version kicks in?
    Reload new version see if it gives the chance to remove before it installs. It has to be removed as you are aware. ?
    Nov 14, 2009 | Computers & Internet
    Is there a Vista 64 print driver for Calendar Creator 8? I receive a file from another individual, edit it and then print copies for a church. About all I can do now is edit the data, save as a graphic...
    Im sorry you are angry with me ... this is not my site - I am just a volunteer question answer guy passing my time in the evening at home while watching TV. I dont understand why you wouldnt goto the source to start with is all.
    Oct 19, 2009 | The Learning Company Calendar Creator...
    Unable to uninstall calendar creator 10 from vista
    RESTORE UR CPU IN SYSTEM RESTORE TO A DATE BEFORE YOU INSTALLED IT
    May 15, 2009 | Broderbund Calendar Creator 10 Full...
    Computers & Internet Logo
    David Payne
    David Payne
