Question about Akai PT46DL10 46" HDTV-Ready Television
Tv not working
Hello again i talked to you earlier and i said that i would be contacting you later about the tv not showing a picture, you told me to look at the fuse. i have just one question, i took off the back and i see two boards but i do not see a fuse. can you please help me?
Some one come and check my tv he said has problem with receiving signal is that true .my tv dint turn on akai hdtv 5598
Posted on Oct 23, 2008
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
Tv doesn't work
If this TV has a lamp it could be it. I need the model number to better figure it out
Mar 08, 2010 | Televison & Video
Wont stay on after power is hit
Hello, I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 30, 2009 | RCA D52W19 52" Rear Projection Television
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a Philips plasma 50 inch tv, I had the red dot problem a year ago. Went through the extended warranty and Andulusia TV service in Bensalem, to repair the problem. They had it for amonth and told me...
the panel is bas. it has a diffusion problem.most extended warranty companies require you to let the shop try 3 times to repair for the same problem. on the 4th time they talk replacement.
best to read the contract.
Dec 17, 2008 | Televison & Video
Pop then dark screen - no picture... New lamp installed and still no picture
Yes you are correct, I have seen this many times. 6 flashes is the thermal fuse
Mar 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red light blinks 3 times
When the senior service tech changed our bulb, I watched very carefully, and he said there is an electrical contact towards the rear of where the bulb goes in that bends very easily and that care is required not to damage or bend that connector. His assistant tech then bent the thing, and the senior tech had to straighten it out properly. All the while, he talked about how delicate this connector is. Hope this is helpful to you. It sounds like what he was talking about.
Oct 29, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Loose Sound and Picture very now and then, but TV stays ON
Check out www.manualsparadise.com There are service manuals available for download. They start at $7.95. That might point you in the right direction.
Oct 12, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Blue screen
It sounds like the high voltage distribution block but that is not the cause of your problems,the tuners you talk about are the picture tubes ,one for each color,the blue picture tube was arking and you got lucky and got 6 more months of use, it and might have corrected when you drop it but now is the red doing it and you need to do the same but it might not work this time,dont be surprise.Be carefull while trying things in the back,there are high voltages there and is not safe unless you are familiar with tv service.
Sep 19, 2006 | Sony KP-61V45 61" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
70 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
