Question about Frigidaire GLEQ2152ES Electric Dryer
Beeps intermittengly Dryer beeps when it is off
  • 414 Answers
Unplug it or switch it off at the wall switch
Posted on Oct 11, 2008
Dryer is beeping
...check the specific beep codes for your dryer. Often if a dryer beeps it's one of two things; obstruction of the barrel which is preventing it from spinning, or overheating. In some newer dryers it'll beep if there is a unbalanced, much like many new washers. However this last one is easily remedied by removing the item that's causing the balance issue. Since you're posting a question on here I suspect this simple answer isn't the one you're looking for.
Jul 31, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs but beeps intermitenly and doesn't stop beeping
you most likely have a bad computer board located in the top console.i haven't changed any of these boards out but on the frigidaire affinity dryer this happens alot and it's the computer board.the dryer would just start beeping on it's own,like 3 beeps at a time beep beep beep,then beep beep beep,was the board,you have to give the full model number to whoever you order the board from,open the dryer door,look around the opening where you put the clothes in and you'll see a tag with the full model number.good luck.
Feb 25, 2014 | Whirlpool GEW9868K Electric Dryer
Dryer beeps while drying
Most likely you have an excess of lint hampering air flow from the dryer. Vacuum out lint filter area, gently remove aluminum exhaust duct behind dryer and make sure it is clear and debris free. Also check exhaust duct port on back of dryer and that the vent going out of your house is clean and not stuck closed or clogged.
Jan 04, 2013 | LG DLE2101 Electric Dryer
How do you turn off the beaping on a Haier Clothes Dryer?
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
Jul 09, 2012 | Haier Dryers
Kenmore electric dryer 66802 timer goes off all the time
Try unplugging it for ten mins or so to reset the chip.
Mar 25, 2010 | Kenmore 62802 Electric Dryer
Kenmore Evenheat MOD# 110 62056100
okay, kenmore elite have had these problems so often, you need to replaced the touchpad, not the board, jjust the touchpad, it cost around $150.00.
Sep 10, 2009 | Kenmore Dryers
Beep beep beep
Temporary Fix: unplug the dryer or cut its power at the circuit breaker panel, when not in use. If the dryer alerts/alarms are set to silent and the beeping happens when it's not in use, chances are it's the same beeping you hear when you first introduce power to the unit or press start. This may indicate a short affecting the control board. If you need to press start multiple times to get the dryer started, then the control board components are most likely starting to fail.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Jan 18, 2008 | Kenmore Elite HE4 Electric Dryer
Beeping dryer
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated). Good luck!
Aug 20, 2007 | Miele Novotronic T230C Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
99 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
