Question about Canon PowerShot A560 Digital Camera
Lens error,restrart camera
Please help me.i need my canon powershot a560 fixed today for my special day.huhuhuhu..how sad..i just fell in on the carpet with its lens extended..please help me..
  • mad24slider Oct 23, 2008
    it says lens error restartcamera and when i restart it it says the same thing ''lens erroe restart camera''
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Posted on Oct 08, 2012
advance
  • 107 Answers
SOURCE: My Canon Powershot SD400 won't turn on and lense won't go back in
Unfortunately the lens assemblies in these compact digital cameras are quite delicate. The drop probably knocked the barrels of the lens out of alignment preventing it from moving. You can try to GENTLY twist the lens back and forth, you may be able to click it back into alignment allowing it to function normally. If the gentle manipulation fails to fix the problem you will need to get the camera serviced by a professional. There are quality repair services on the web who will work on your camera. David Millier Advance Camera Repair
Posted on Mar 06, 2007
t00nz
  • 4738 Answers
SOURCE: Lost my Canon PowerShot A560 disk
As a solution I highly recommend that you forego the old cable to the camera route, and instead consider a card reader to download your photos to your computer. Card readers are very inexpensive, much much faster downloading photos from the camera, do not use the camera's batteries during download, and are much less prone to file corruption of the photos during the download.
You place the camera's card in the reader, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For all of these reasons, most professional photographers utilize card readers exclusively. Really, you'll save yourself a lot of headache. Here are some examples from Amazon. Also, don't be fooled by the cost. some of the cheap ones work just fine. Go by the reviews. Also make sure you get a reader that is stated capable of reading your card (particularly if you have an SDHC card):
http://www.amazon.com/s/qid=1232260593/ref=sr_st?keywords=sd+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Asd+card+reader&sort=acrelevancerank
For international readers, here's another source for card readers (free international shipping too :-)
http://www.dealextreme.com/products.dx/category.300
Posted on Jan 21, 2009
SOURCE: Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
Posted on Oct 06, 2009
  • 11967 Answers
SOURCE: Clicking noise when PowerShot S3 lens extends and retracts
Save this for the future if and when a "lens error" appears: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 10, 2010
  • 420 Answers
SOURCE: can i fix lens error on canon powershot a560 my
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 11, 2010
How do i fix the lens error on canon powershot a480
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101;'';
Jan 25, 2011 | Canon PowerShot A560 Digital Camera
Camera wont turn on anymore. it says "Lens error,
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Jan 03, 2011 | Canon PowerShot A1100 IS Digital Camera
I tried to connect a power supply to my Canon Powershot A560. (wont ever do THAT again.) I am getting the "lens error, Restart camera" message. The lens ill not close either. How do I restart?
Unfortunately I fear that you have plugged a wrong power supply and possibily damaged the camera mainboard. Since these boards are very delicate just a momentary power can damge these circuits.Hence I request that since the fault occured due to a forced problem it is important that you take help from a camera service centre or preferably Canon to look into the seriousness of the fault. take estimate and decide if resonable. Good day
Aug 16, 2010 | Canon PowerShot A560 Digital Camera
Can i fix lens error on canon powershot a560 my self
try these:-
  • shake it.
Jul 12, 2010 | Canon PowerShot A560 Digital Camera
Hi, i dropped my a560 the other day and the end part of the lens bent a little but i managed to put it back in its original form. however when i press the power button the lenses whirrs and tries to open...
sounds like when you dropped it it damage the gears in the camera that make the lens not work properly , you may want to take it and get it fix by the maker of the camera sorry.
Nov 29, 2009 | Canon PowerShot A560 Digital Camera
Canon powershot A560
you need to get camera serviced-usually lens jumps off track or is crooked and gets jamed-did camera get dropped?if older model than 1 yr usually 100-125 to repair-if new model still in warranty they will tell you someone broke it and it's not covered-as a last resort if you are going to toss camera anyway put pressure on lens as you try to zoom in and out or put lens between teeth and try to force back in place
Aug 12, 2008 | Canon PowerShot A560 Digital Camera
Powershot A560
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 15, 2008 | Canon PowerShot A560 Digital Camera
Canon PowerShot A560 Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
