Question about Gestetner Copier
Gestetner DSc332 Printer error from PC. Printer will not reset. Print jobs have been cancelled. Continues to have message on screen saying resetting job.
  • Anonymous Nov 05, 2008
    The printer won't reset it just sits flashing and thinking about it. Have tried power off but nothing works! Help please!!!!!!
  • 903 Answers
Sometimes a job will get caught up in memory. If you've already tried to reset the job from the copier and from your computer, turn the copier off with the main (orange) power switch and unplug it from the network cable and the wall. Wait 30 seconds, then plug it back in and turn it on.
Posted on Jul 18, 2010
How do I cancel a print job on an hp 5500 series
Press the Cancel Job button. Ensure you have have deleted the job from the PCs print queue. If issue continues, unplug printer, reset ram, restart
Feb 20, 2015 | HP Office Equipment & Supplies
I can't reset printer. The green light is flashing and screen is saying busy
Sounds like info is "stuck" in the buffer. To clear it out, turn the printer off, wait three minutes and turn it back on.
Nov 13, 2012 | HP OfficeJet J4580 All-In-One InkJet...
We have the E260d. What does it mean when the light bulb flashes. We are unable to print. What can we do?
You can unplug the printer from the wall, then leave it off for about 30 seconds then plug it back in. That should reset the printer, if not read what the message says on the screen, or you may have to navigate through the settings to see the error message.
Jun 29, 2011 | Lexmark C533DN InkJet Printer
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 04, 2011 | Brother MFC-490cw All-In-One Inkjet...
Prior to past few days printer worked fine. Now it prints a few postcards then gives a print buffer message on printer screen and from there on it prints gobbledy gook. Now it won't even print a test...
Sounds like you cover all the bases. I just wonder if you reset the unit via the service mode?
resetting the printer should have cleared the memory.
Hold down select and return while powering on machine, hold until self test comes up on display then press go, this will get you into service mode.
Run the memory diagnostics.
Nov 23, 2010 | Lexmark T642 Laser Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
If no PROGRESS METER appears, you can access the document queue in this fashion:
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
How to cancel a print job
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
Printer gets stuck with a "Printing ..." or "PC Print ..." message on the LCD display
I have the same problem with mine. Another option is to "Log Off Administrator" at the PC or "Restart" the PC and prior to shutting down it seems to pfrint all my jobs ... better than cancelling.
Jan 26, 2007 | Samsung SCX 4521F All-In-One Laser Printer
148 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
