Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer beeps when it isn't running
My Frigidaire front load dryer beeps intermittenly when it is not running.
  • Anonymous Oct 17, 2008
    I am having the same problem. Some times I get an error code E68 which is a stuck key code. This dryer has worked for 2 years so I'm not sure why now a circuit card would go bad. Any suggestions on fixing this?
    Problem Solver:
  • 7 Answers
Sounds like the control board, is there any codes displayed?
Posted on Oct 16, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
When I press start dryness cicle not working. Appears error
Hey Salvador Juarez, I appreciate your post!
I understand that when you try and press the dryness cycle on your Frigidaire laundry center it provides you an error. I would like to ask you some additional questions in order to best assist you. Does it show you a code or beep? If so, how many times does it beep? I look forward to your response. Thank you. -Matt
Aug 02, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
My frigidaire front loading dryer just keeps beeping
see the diagram and proceed the troubleshooting for fix it.see the fuse or switch door faulty.
Jun 19, 2012 | Frigidaire Dryers
I have a frigidaire gallery series front loading electric dryer model # 134509400c.press start and it beeps with a dr code.any idea what is causing this?
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires you can inspect these relay connection visably by removing the front control panel you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay this is not a factory taught test.its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is fried
Oct 22, 2011 | Frigidaire Electric Dryer
I have a Frigidaire GLEQ2152ES 5.8 cu front-loading dryer. For the past year I have had no problems. Today I went to put in the first load and when I tried to start it I got nothing but 3 beeps. Even...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 29, 2010 | Frigidaire Dryers
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
1,090 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
