Question about Nokia 6600
Receiver of call feom new 6600 unable to hear
All settings are correct but when I make a call, it connects, but the person receiving is not able to hear me.
  • samuelcg-car Sep 21, 2008
    Thanks. I suspected this as it works on the blue tooth speakers in my car. Hope to have it replaced as it is new
    Carol
    Brigadier General:
  • 7,752 Answers
The microphone needs to be replaced on the phone to correct this.
Posted on Sep 21, 2008
Denon avr 1507.recently replaced with new set of speakers.sound got dropped.keeping full volume only i can able to hear something.
Are you using normal impedance speakers? If it worked correctly before, and even better if you can connect the old speakers back to verify the receiver works correctly, would give you a clue.
If the new speakers are a difficult load (below 4 ohms) it may overload the amplifier and it will shutdown to protect itself. You need to provide more info to access correctly.
Removing all speakers and using a headset will also validate the operation of the receiver.
Good luck.
Jan 30, 2015 | Denon AVR-1507 Receiver
I can not hear person calling on iPhone but they can hear me
try to put person on speaker phone. If you can hear then your receiver is defective and if you can't hear then, follow instructions here.
http://support.apple.com/kb/ht1414.
Make sure to backup your phone before you do that.
Oct 06, 2014 | Apple iPhone Cell Phones
I have a denon avr-1611 and can get sound playback through my connected speakers (not tv speakers) but no video output from hdmi. I have the receiver connected to a samsung tv. Is there any fix for th
You should check your Denon manual to be sure that the receiver has been set up correctly. My 1913 has many set up options including associating a particular HDMI out connection with a particular source like CBL/SAT or DVD. The fact that you hear sound indicates the HDMI cable connecting the cable box or DVD player to the receiver is working ( at least the sound portion of the HDMI in cable.)
Next, is the HDMI connection you are using to the TV the one selected in the source listing on the TV ? The sound and video circuitry on a receiver are separated and you can hear sound but see no video if the TV isn't selecting the correct source. For example if the TV is set to HDMI1 but you are plugged into HDMI 2. If this doesn't solve your problem try this:
At this point you don't know if the problem is the receiver HDMI connections or TV HDMI connections or a bad HDMI cable. The first thing to try is a new HDMI Cable. If that doesn't solve the problem then do the following.
If the TV has more than one HDMI connection try another HDMI port. Be sure to switch the source on the TV to the new HDMI port ie. HDMI1,HDMI2 or whatever.
If this fixes the problem you are done. If not then Try the same thing with the HDMI out ports on the receiver. Try each one not forgetting to set the receiver to use the HDMI port you are testing.
each time.
Since this can get confusing I would write down what you are testing each time so you don't get lost or confused.
If none of this works then you can try hooking up another TV to the HDMI cable, if you have one. If you do this and you still have a problem it points to the receiver as being the culprit.
The most likely problem is you have misconfigured the system so that is where I started. Each test is dependent on the fact that your system is correctly configured to begin with.
Sep 04, 2014 | Denon AVR-1611 A/V Receiver - 3D - 75 W...
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
MY NOKIA 6600 IS NOT GETTING CHARGED
the problem with other people unable to hear your voice, when on a call is the problem with the mobile's mic. you can take it to a service point and check with them
and for charging problem, i can just suggest you something, not sure if that would be a solution. Try removing the battery and sim for a few mins. then insert sim and battery and try charging
Dec 02, 2008 | Nokia 6600
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Nokia 6600 Logo
Top Nokia Cell Phones Experts
IT Solution
IT Solution
