Question about IBM ThinkPad 570E Notebook
Line on laptop screen
I have a IBM 570e I have a line down the right side of my screen is there anyway to get rid of it.
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
May 10, 2014 | Proscan Televison & Video
Hi IBM Thinkpad 570e The Keyboard has stopped working on keys 1,Q,A & Z. Do I need to replace the keyboard please? Regards
Try taking the keyboard out and re-seating the connection, there should be a manual on how to remove it...actall here... http://www-307.ibm.com/pc/support/site.wss/MIGR-4793QA.html
This is the downloadable manual to show you how to do it but please be carefull and take your time. Take the connection out and and put it in again and try that, failing this you will need a replacement keyboard, you can get one on ebay - http://cgi.ebay.co.uk/IBM-ThinkPad-570E-Laptop-Keyboard-Tested-0583-/230590820594?pt=UK_Computing_ComputerComponents_KeyboardsMice&hash=item35b048b0f2
Hope this helps
Mar 18, 2011 | Computers & Internet
Need a pc card for wireless internet connect.Have tried netgear does not work in computer. any suggestion. model of computer 570e imb thinkpad. old computer work great but need internet connection. thanks
You can order pretty much any PCMCIA Wireless network adapter. If the machine is older, you may want to try the "802.11g" or "802.11n" wireless notebook network card.
Try Belkin F5D7010, it uses the "g" signal band.
Apr 28, 2010 | IBM ThinkPad 570E Notebook
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Sep 07, 2009 | IBM ThinkPad 570E Notebook
I loaded a new, formatted IDE hard drive into an
If IDE drives are hooked to the same controller one must be configured in BIOS as Master, and the second as slave.
If there is only one drive, it should be set as master: Two drives on two different controller must be both defined as master.
Hope it helps.
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
IBM 570E Notebook password locked
The olny way to clear a password is to take out the CMOS battery and rejump some jumper settings on the motherboard.  In a laptop, this can be very tedious and difficult.  I would suggest unless you have extensive knowledge in taking these apart, take it in to a repair shop and have them do it.  I don't know where you live at, but around this area I charge aobut 25-40 bucks for a laptop to reset, depending on the model.  Older models are a little cheaper because they are easier to get at.  You could attempt it yourself, but please do not try this unless you are very comfortable with what you are doing as you could render the laptop into a giant paperweight.
Mar 22, 2009 | IBM ThinkPad 570E Notebook
IBM Thinkpad 570E motherboard
Once you install the OS, you can go to Lenovo for the drivers:
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Jun 11, 2008 | IBM ThinkPad 570E Notebook
Can't get the cd drawer open
There is a hole in the front of the drive - just stick a paperclip in it to manually eject the cd.
Dec 19, 2007 | IBM ThinkPad 570E Notebook
IBM ThinkPad 570E Notebook Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
