Hitachi AX-M140 hi fi, cd players says no disc when you have put a disk in, this happens with copied and original discs. It doesnt happen every time, sometimes it plays straight away, other times you have to keep opening and closing the draw, any help would be appreciated as I love the look and sound from this unit, many thanks, Clive Casey
  • Anonymous May 09, 2009
    the cd won't read says no disc and you have to keep opening the draw, any solution
SOURCE: sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Posted on Sep 29, 2007
  • 231 Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Posted on Mar 04, 2008
SOURCE: how do i reset a
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Posted on Mar 10, 2008
SOURCE: I have a Hitachi AX-m133
I recently got one of these and had the same problems. These were solved as follows.
Firstly, for small devices such as USB sticks and MP3 players they must be formated as FAT32 otherwise they cant be read, NTFS does not appear to be supported.
Secondly, for portable hard drives they must be also formated to FAT32 they also need to be externaly powered. For my 2 1/2" lap top drive the power from the USB port on the machine was not enough to fire up the drive I had to use a Y cable plugged into a mains usb charger to boost the power it then worked fine. Also be a little patient as it will take a little while to read the drive, this will depend on the drive capacity but you should hear the drive ticking over as it does this
Posted on Jul 12, 2008
I have just filled out a question form before Joining. So here again: It is a need to clean a hi-fi CD playing lens.
It is possible the laser or other part of the CD player is faulty.These can stop working for no apparent reason at any time...
I had a Sony system that also refused to read the cleaning disc. I had experienced laser failure twice before on other equipment and hoped it hadn't happened again as the cost would be disproportionate. This also couldn't be accessed for manual cleaning and so I used a compressed airline and blew through every orifice with the drawer open and drawer closed.
I was lucky and the CD player was again able to read a disc again though a few months later it stopped working again for good. The repair cost would have been half as much again as a new system but I had the remarkable stroke of luck to find someone had put an identical model out for the garbage and so I changed the internals and have continued to enjoy my CD for the last few years, though it is again becoming temperamental.
Sep 21, 2016 | Kenwood Audio Players & Recorders
Try a Lens Cleaner CD.
Go to a store that sells electric goods. Ask for a CD Lens Cleaner disc.
Sep 13, 2014 | Audio Players & Recorders
Dvd player reads "no disc" when I put disc in
Are the discs copy's or originals if there copy's some systems will not read them, if there originals then clean disc on laser eye with a cleaner disc
Mar 07, 2014 | Sony BDP-S350 Blu-ray Disc / DVD Player,...
My cd player when i put a disk in it ,comes up optical error
Try a original disc. Some players will not read copied discs.
If it is an original disc it may need to be cleaned.
Jul 17, 2011 | Chevrolet 1500 Cars & Trucks
I have a Hitachi AX-M131.U. Hi Fi. I have downloaded music from iMesh on the internet,but the cd's will not play,they play on my computer/car cd / and TV ok the cd's that I am downloading to are Tesco...
Download and install CD Burner->click here
Start the application and select Audio Disc -->click OK.
Drag and drop files ...and click burn.
Select burn speed 24x.
Apr 05, 2011 | Hitachi Electronics - Others
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
What the E-20 showing on my cd player
Hello! The "E20" error code loosely means that the CD player cannot focus, or read the disc properly. This could be from a number of reasons, dirty pickup lens, dirty/scratched disc, excessive humidity, or using a burned/copied CD that was burned at a speed that was too fast to provide a "deep" enough burn to the disc. And lastly, I know GM's Delco radios in the late 90's had issues reading CD-RW's; but read CD-R's fine (if burned slow enough)
My first suggestion would be to see if this happens on all CD's - originals and/or burned ones. If it only happens on burned/copied discs - I'd recommend slowing down the burn speed to no faster than 16x and retrying. If it does happen with both types of discs, then I'd purchase a CD lense cleaner and run that through a couple of cycles.
Hope this helps and good luck! Thanks for using FixYa!
Sep 26, 2009 | 1997 Pontiac Bonneville
AX-M140 problems, problems
Hi mate... yes we got cut off and I couldnt find you. Appears you have surfaced from the depths of the server. can carry on talking in here is you like. It is almost real time.
Jun 05, 2008 | Hitachi HTD-K170 System
Hitachi Hi fi module ax-m140
Use a computer to rip your CD's Then copy them to a memory stick. Then you can plug the memory stick in and copy the files to the hard drive that way. Each files takes about 5-10 seconds. Hope that helps
Jun 18, 2007 | Hitachi HTD-K170 System
104 people viewed this question
