Question about LG 42LG50 42 in. LCD HDTV
Unable to control channels or volume
LG HDTV remotes suddenly quit working, when turned on manually the volume goes all the way up and you cannot control anything.
    Scholar:
  • 86 Answers
Is the remote a universal? Make sure you select TV as the the device you are trying to control. You can also fix a wonky remote by popping out the batteries and mashing down all the buttons. This rids the remote of any built up electricity that could be hampering functionality. Also, the remote sensor on the TV is controlled internally of course so a power drain of the TV wouldn't hurt:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
What do the buttons on the TV itself do? Do they work properly? If not, the problem is going hand-in-hand with the remote and again, the problem is internal and service or a firmware update, if available, may resolve this.
Posted on Oct 17, 2008
I have a Panasonic TH-42PX50u that suddenly is stuck on one channel and no volume control either. Same whether using remote or on TV. Only turns on and off no other control.
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Look for jammed buttons on remote and/or on control panel. Try removing the batteries from remote and operating from the control panel of TV. If these are ok, Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 06, 2012 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The remote control (LG AKB32559904 TV REMOTE CONTROL) suddenly quit working properly. We changed the batteries and all it would do is the volume control...with ANY button you pushed. It would turn the...
Replace the remove control first. You can get universal or even an replacement original remote. If problem by slight chance persists, then ir sensor may be faulty.
Nov 19, 2009 | Computers & Internet
The volume on my lg ty quit working. It will not
I hate to give you the bad news, but this is not an easy fix for a do it yourself-er. you will need the internal diagram to fix this. There is an IC (intregrated circuit) chip inside that has most likely failed. I would recommend that you take it to a qualified repair shop for estimate or repair. There is really nothing in this case that you can do to fix it yourself without the proper equipment.
if you have an external jack for hooking up a surround system you may try to route the volume through this type of device and control the volume that way, but this is just a temp solution. Best of luck to you, I hope this helps.
Sep 11, 2009 | LG Televison & Video
Need remote code for LG HDTV model 47LG90...
Just bought an LG 32" HDTV and have the new Samsung STB, with a Scientific Remote; the code in the remote manual for LG says to use 1005, but after trying it and many others, I used the "Find Code" set-up (991) and (990) in the remote manual and happened upon 1004 for the LG.
While this worked, the remote is a bit awkward, as you have to enter yet another code (998) in order to control the Power for both the TV and Box with the remote; the good news is that the instructions to do this are pretty straightforward and well presented.
Now, I can turn both TV and Box on/off with power button on remote, can change channels with remote and also vary volume with remote!
Hope this helps
Mar 29, 2009 | Televison & Video
LG 42LG50 42 in. LCD HDTV Logo
395 people viewed this question
Computer Repairing
Computer Repairing
