Question about Bose Acoustimass 15 System
Bose Acoustimass 15 System no power
Hello if any one can help. My Accoustic mass 15 system has no power. It still passes thru to my received but the sub stop working. I can disconnect the power and reconnect and nothing. I have opened the case and checked the fuse -is good. Any ideas? anybody?
Thanks.
Joe
  • 2 more comments
  • Anonymous Sep 21, 2008
    I have the same problem any idea how to fix it?
  • Anonymous Oct 16, 2008
    Someone help!
  • gyoschak Oct 25, 2008
    Same problem--my sub makes a buzz for about 2 seconds after I turn the power switch on, then stops. No sound output at all other than that.
  • Kim Williams May 11, 2010
    That isnt wax, It is glue and it was put there by the factory so they know if you have been swapping things out and voiding your warranty.
Same problem, i found the transformer looks like the wax or glue melted down on the cir board . . . not sure if that the problem but has anybody seeing the same ?
Posted on Nov 25, 2008
I aquired Bose Acoustimass 15 surround sound through home purchase. Hooked wires up to reciever and hdmi to tv and i got nothing. my question is, how do you turn on the sub? just plug it in?
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
Aug 02, 2014 | Bose Acoustimass 15 System
Location of serial number on Bose L1 s1
The serial numbers for the L1® 1S Cylindrical Radiator®s are on the back. The serial number for the Power Stand is on the bottom of one of the legs.
Sorry, I can't help with the Acoustimass system.
Feb 17, 2014 | Bose Acoustimass 15 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Bose Powered Acoustimass 30 Speaker System
The master on/off switch will usually be on the back (or maybe even the bottom) of the largest component, which contains the power and control circuits.
Nov 28, 2008 | Bose Acoustimass 15 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Acoustimass 9
Acoustimass 10 IV cable
Feb 29, 2008 | Bose Acoustimass 15 System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System Logo
552 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
