Question about Microsoft Zune JS8-00001 Digital Media Player
My Zune froze and shut off, it won't turn back on.
I've tried putting it on hold and pressing the play button and tried plugging it in, even. It will NOT turn on. E-mail me if you have any answers. McDermott_14@hotmail.com
  • 2 more comments
  • Anonymous Dec 20, 2008
    Why are people posting questions as solutions? Hell i did it too! Oh well i have the same problem, someone help!
  • Anonymous Dec 31, 2008
    my zune froze when i was turning it on.its showing the zune buffering mode,when the line should reach the "100%" but it froze.i tried to turn it on and off on different ways,but its showing still this picture or its still in this mode.pls help
  • allinhonor Dec 31, 2008
    Same thing, got to 100% on the load as soon as I turned it on and I can't fix it.
    I've tried all of the different reset things and nothing will work.
    It's 30 gigs.
  • Anonymous Apr 18, 2009
    my zune wont turn on period, i tried to turn it on after an apointmen and it just wouldnt
I had the same thing happen to me. what you want to do is hold the back button down then the up circle key for about 5 to 10 seconds, that should solve you prob
Posted on Nov 04, 2008
  • fixingit073 May 25, 2011
    mine did not work:(..but i feel heat when i plug it to the charge
IT WORKS!!! All you have to do is hold the back button and the up circle for about 10 seconds and i promise you that fixes it! Thanks Kutaphish for all the help!!
Posted on Nov 12, 2009
Thank baby jesus it worked!!! Very helpful and very effective!!! Thank you veryyyy much!
Posted on Jul 06, 2010
2 Suggested Answers
jeffsterrett
  • 108 Answers
SOURCE: blinking screen turning on and off
Mine does this if I let the battery get too low. In order to fix it I have to open the case, unplug the hard drive, plug the zune into my laptop and let the battery charge for a couple of minutes. I then turn it back off, plug in the HD again, replace the case, and plug it back into my laptop and it boots just fine.
I Imagine this means I have a weak battery (trying to spin the HD drops it below minimum voltage), but maybe this'll help someone else get up and running again.
Posted on Sep 15, 2011
My Zune HD won`t turn on, what do i do ? =]
Hold the power button for 10 seconds. this should cause reset. if it does not hold it again for 15 seconds this should cause it to power into repair mode where you will then need to plug it into your computer and update the firmware with the included software. hope this helps!
Apr 15, 2010 | Microsoft Zune HD MP3 Player
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
My zune just stopped working
run the battery completey dead or you could possibly reset the device to factory default...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
How do I shut off my zune!?!?
hi,
keep pressing the play button for 10seconds. it must shut off.
thanks you
Feb 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune wont charge
unplug the zune. hold the back button and hold the up button until the zune restarts. wait until it turns back on. open the zune program. then plug in your zune. it should work.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Mirosoft zune froze up
To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune wont turn on
I turned on my Zune and the screen froze so I turned it off but it would not turn back on.
I went online and read somewhere that if the screen freezes then you should press up and back and wait for the zune insignia to come on. Well my zune was not just frozen it would not go on but I tried the up and back thing and it worked. it took about 9-13 seconds but it worked so give it a chance and if that doesn't work try charging it overnight. Hope that helps :D
Nov 12, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune Won´t turn on
my son's just did this and the reset method worked (press the back button and up and hold both for about 10 seconds until the zune screen appears)
Nov 08, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
2,584 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
