Front loader washing machine door wont lock to begin cycle?
  • stecon Apr 13, 2009
    The fuse blew in my wf000 and when i replaced it the door would not lock to start the cycle, i have changed the interlock, but still nothing, whats next??
I had this problem with my Kenmore HE4t -- when I pushed the Start button the door would not lock. It just made a little click noise. In my case the problem was solved by unplugging the machine (or flip circuit breaker) for a minute. When I plugged it back in, lights blinked, I pushed cancel, and after that the machine works fine. Hope you have such good luck.
Posted on Apr 07, 2009
  • 958 Answers
You might have a defective door switch. this is the part that locks the door and sends a signal to the processor to say that the door is already closed.
check also the wires that goes to this door switch. it could just be loose connection.
tnx 4 using fixya,
drcool
Posted on Sep 20, 2008
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool front loader washer door remains locked
Here is one way: http://www.youtube.com/watch?v=gSF4JS2B_U0&playnext=1&list=PLoRcTDdjR-2afhmUpe11VXBKUReLA8CAa&feature=results_video
Jan 27, 2013 | Whirlpool Washing Machines
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
My front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Mar 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
385 people viewed this question
Top Washing Machines Experts
