Question about Optoma EP737 - DLP PROJECTOR - 1500 LUMENS *NIC* Multimedia Projector
How to change bulb in optoma EP757 DLP projerctor?
Mounted on ceiling
  • VEESWFL Sep 21, 2008
    how do i change the bulb in a optoma DLP EP757 projector/
SOURCE: Help needed for Optoma EP 719 DLP PROJECTOR
picture upside down
Posted on Jul 28, 2008
  • 3 Answers
SOURCE: replacment of bulb on dwin transvision 3 plus ceiling mounted
It is fairly simple. Take the unit down as you need to get to the underside. There you will see the retaining screws that hold the cover on. Remove these and open the unit. Inside you will see the bulb and mounting bracket. Off hand I don't remember exactly how it is held in place but there are a number of screws and a lead to disconnect to remove it.
Posted on Apr 30, 2009
projdoc
  • 2237 Answers
SOURCE: Just mounted my Optoma EP732B projector on the
go into the menu settings, and look for image. should say "front", you'll want to change it to "ceiling"
Posted on Nov 16, 2009
SOURCE: ceiling mounted PJ551 - lamp light red, power light blinks red
I have PJ 550 exact SAME PROBLEM replaced bulb NOTHING
Posted on Sep 12, 2010
  • 2385 Answers
SOURCE: What is the price for Optoma EP757?
it is out of stock product, because the production is no more done throughout the world, Although you can buy used or refurbished system from their own price.
good luck
Posted on Nov 28, 2010
Have optoma ep738mx projector is set for ceiling mount want to change to desk mount
Need to check on the menu to see if the provision is possible , open menu and scroll to see if the screen can be inverted. If not you will need to get help from Optoma dealer , Check on the rear for any trip switch to change the settings as I do not have the manual for reference.
Dec 06, 2011 | Optoma EP738 Multimedia Projector
The image projected is upside down
not sure where it is in that model as #I have 700x, however theres an option for whether it is ceiling mounted or not, turn that off.
Jun 09, 2011 | Optoma HD65 DLP Projector
Purchased 2006. Ceiling mounted. Just stared overheating after approx 10 minutes after last bulb replacement in March of 2010. Floor fan pointed at projector helps. Tried cleaning. Running right side...
Yes, if bulb was low price and was installed in old lamp casing then it is bulb that is not good and creating too much heat that exhaust fan can't throw out to make projector cool enough so temp sensor activates and send over heat signal to system control chip thus projector shuts down.
Please install original lamp that comes with casing to solve this issue.
If lamp was original then check exhaust fan that might be running slowly due to stiffness in bearing so temp sensor finds over temp in projector.
Hope these info will help you.
Thanks.
Dec 18, 2010 | Optoma EP1690 DLP Projector
good luck
Nov 28, 2010 | Optoma EP757 Multimedia Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
Optoma EP757 displays green image when input connected. Initial splash screen displays fine. All colours are the way it should be but as soon as a video source is connected, it displays the image in...
I would suggest replacing the type of cable you are using. Changing the type of connection, such as S-Video or VGA or something other than what you are using, may resolve this issue as well. Because the splash screen comes up normal, this tells us that the issues lies not with the device but with whatever it is you are connecting it to. Comment back if this does not resolve the issue and we can move further.
Good Luck,
NOLA Tech
Jan 27, 2010 | Optoma EP757 DLP Projector
Just mounted my Optoma EP732B projector on the ceiling. Can't figure out how to get the picture to not be upside down? Help!
Nov 15, 2009 | Optoma EP732 - HDTV Compatible DLP...
The optoma hd72 projector lamp goes out after 30 seconds.. the big game is this weekend... what can I do?
I had this exact same problem. I have changed bulbs gotten 1000 or so hours from new bulb, changed the lamp driver and gotten about 600 more hours from new lamp driver. New lamp cost me $350, lamp driver cost me $120. Then I read on a page to try and flip it right side up, because I had it ceiling mounted upside down. I flipped it right side up and it works perfectly and has been working perfectly for 2 months now. I know it sounds stupid, but it actually worked for me, and it costs you nothing to try it. For some reason, gravity effects this unit.
Jan 31, 2009 | Optoma HD72 Multimedia Projector
EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Nov 18, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
665 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
