Question about Malber WD1000 Front Load Washer/Dryer
Malber WD800 disbalanced
One of the wheels of my Malber WD800 was bent a little and my husband decided to help me - he flipped the machine on its side to take a look and fix it. When we put it back up straight, the cement block inside the machine, apparently, had shifted and the machine is now disbalanced. The gasket that seals the door is actually twisted...
HELP! Ithis repareable??? If it is, is it smething we can do or we need a professional to fix it?
Thanks!
  • 13 Answers
SOURCE: Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Posted on Jan 07, 2008
  • 55 Answers
SOURCE: Malber WD800 - Will not fill
The thing making noise is probably the inlet valve, not the pump. The pump pumps the used water out the drain hose. Anyway, if the noise happens when water is trying to come in, the inlet valve is probably faulty. Onw way to get around this without repair is this: If you are hooking up to the sink, that means you are using only one hose to the machine. The other inlet to machine is probably capped off. Remove the cap, and the hose to the respective inlets, and reverse. You will probably have to change your water temp selectors on the front of the machine. If this makes it run OK, then you can later buy an inlet valve and replace at your leisure. For parts call 718-767-7396 in NY. I hope they will ship to where you are. Good luck and let me know what happens.
Posted on Mar 21, 2008
  • 55 Answers
SOURCE: MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
Posted on May 06, 2008
  • 6277 Answers
SOURCE: Hello,I would like to know how to use my malber
Just in case please try the following- it could be that there is water still left inside the washer which is why the towels do not dry.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 09, 2011
SOURCE: MALBER WD 800 Features
How can I get a copy of the manual??
Posted on Jul 04, 2012
Grey wire come off on Malber WD1000 dryer
Your picture was a big help in figuring out your problem.
The "secondary thermostat" (the little round one) has two terminals, both designated "T13". An orange wire connects the left terminal to the top of the "Working Thermostat" (nearer the front - with long sensor probe), and TWO gray wires connect to the right terminal.
In your picture, one of the wires looks brown. It's not. That's just a gray wire that got hot. Connect your loose gray wire (it should be marked T13) to it, so both gray wires connect to the right terminal spade.
So your hunch was correct.
Funny, I've repaired 40-50 WD1000s over the last 8 years, and I've never seen or heard of a machine shaking these spade connectors off. They go on TIGHT, and stay on! So, your experience is a new one for me.
Mike (Wash DC suburbs)
Jan 03, 2015 | Malber WD1000 Front Load Washer/Dryer
Malber wd800
if there is no blockage in the screens at the hose connection then u may need a new water inlet valve
Apr 06, 2014 | Washing Machines
Malber wd800
Water-Melon. Ok? W-A-T-E-R-M-E-L-O-N :D
Sep 09, 2013 | Dryers
What could be the problem if rear driver wheel is leaning out like it is bent? I ran up on a curb and now my driver rear wheel is leaning out some and my front wheel feels like I need an alignment or I...
The best thing to do is to take it to a local Frame and Alignment Shop and have them put the vehicle on a Frame Machine and take measurements to determine what is exactly bent before throwing money on parts you might not need.
May 28, 2010 | 2001 Dodge Stratus
Possible Strut Problem....Is My Husband Right??
I dont know what kind of "tests" they could have done....But find a front end shop and tell them what happened and have them find the source of the rattle. Check the sway bar links, check for anything bent. Is the steering wheel straight? does the van now drift to one side or the other when the steering wheel is released while driviving? You coul dhave a bent strut. if so replace the pair and have a alignment done. Go to a independent repair shop not any type of Chain Store (midas, meinke, goodyear, firestones, tires r us ect.)
Mar 13, 2010 | 2000 Toyota Sienna
I have Malber WD1000. Hot water run through the pipe, but do not fill machine. How can I find and check the filter of hot water in machine
Hello. Just turn off the water and then remove the fill hose which goes from the water faucet into the back of the machine. Examine the entire hose and pay closest attention to the filter located at the end of the hose nearest the faucet. regards, Joe
PS - please rate my answer as helpful Thank you.
Feb 08, 2010 | Malber WD1000 Front Load Washer/Dryer
Malber doesn't even turn on.
Clight16 is very likely to be correct. I repair Malbers (in the Wash. D.C. area) and have found door switches to cause these symptoms 90% of the time. BUT, that doesn't necessarily mean replacing the switch. Here's how to test: First, check out the little square hole where the door latch (on door) fits into the machine. You'll see a white plastic "frame", and behind it, a black plastic piece that slides to the right. We'll be sliding that "slider" a little later. OK. Turn machine off (if it's been on). Wait about 2 mins until "safety latch" disengages. (Don't force handle - it can break!). Open door. Set top right knob to "Off" position. Press "Start" button (power on). Turn top right knob to "Beginning of wash cycle". Because door is open, nothing happens - yet. Finally, using a small screwdriver, or other thin object, slide that black plastic "slider" over to the right (about 1/4 inch). Don't be afraid. There is nothing anywhere back there that you can hurt - or that can hurt you. It's totally safe! That simulates the door closing and the metal latch forcing the slider over. My hunch is, the machine will start working (filling with water). If so. you have a simple (and free) fix. The problem is: the metal latch is not forcing the "slider" over to the right far enough. To fix: You need to "allow" the latch to move a little further to the right. To do this, you'll enlarge the hole (on the back of the door) the latch protrudes through. The square hole is sized to stop the spring-loaded latch in the exact right spot. Press the latch back, and file (or scrape) away a little plastic on one side of that little square hole - so when you release the latch, it snaps over a bit farther than it did before. You only need the latch to "lean" over a LITTLE farther (1/16") so only remove 1/32" of plastic. That should do it. And may God bless.
Jan 25, 2009 | Malber P21 Front Load Washer
May 02, 2008 | Washing Machines
my malber sounds like a jet plane lifting off at various points during the cycle, when it's spinning, I am pretty sure.  Any ideas?
Mar 21, 2008 | Washing Machines
Leaking from the front top of machine immediately when cycle begins...
Not sure if this is the same problem but my old WD800 used to spew water out of the top left corner where the detergent tray is. This occurred at one point in the cycle. It was cured by turning down the incoming water pressure on the external tap under the kitchen sink (in this particular case, the cold water)
Jan 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
82 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
