O remove:Disconnect battery negative lead.Disconnect positive lead and connector of starter relay.
Remove three fixing bolts from starter motor. Top bolt also holds the cable support.Slide starter motor to rear, turn and lift upwards.To reinstall:Transfer locating bush to new starter motor.
Reinstall in reverse order.Torque bolts to 50nm.
Make sure you removed three bolts. two are for the housing. One is for the brake or transmission line bracket. I couldn't see why it was in the way but my starter came off after I removed it.
I took out the bolts but the starter will not come off. What should I do?
