Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
WHIRLPOOL CABRIO DL ERROR
DL ERROR WILL NOT CLEAR
CAN HEAR LOCK TRYING TO ENGAGE WILL NOT STAY
IT MOVES IN AND OUT FREELY WITH A SCREEW DRIVER
  • 958 Answers
Even it moves freely , this should be done by the machine, if it does not do that then the door lock is defective.
tnx 4 using fixya,
drcool
Posted on Sep 20, 2008
    Genius:
  • 1,550 Answers
The DL is a door lock error but it can also mean an error with communication to the main control board o
First try to unplug all your connections to the main control board and plug them back in and try it again.
Sometimes a wire harness just may be loose.
If that does not work.
You need to replace main control board .
SAM ANDERSON
Whirlpool cabrio will not complete a was cycle without dial flashing green and code dL in window. Moved from maryland back home to Newport north carolina
I believe for your model 'dL' stands for 'door Lock' (error). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of washing, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 31, 2011 | Whirlpool Washing Machines
I cannot get my washing machine to work. The message,add garment stays on and there is a dl code and it starts making a clicking noise like the lid will not lock
Absolutely right!
'dl' stands for Door/lid Lock error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest ;-0(
John C
Jul 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
GHW94OOPWO....has been solid as a rock for 6 years.....Wont fill up tried to restart and got F flashing then dl flashing steve in sv
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Thank you
Jul 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WASHER WILL NOT SPIN dL KEEPS COMING UP
dL error - means open door lock switch with motor running, what you need to do is unplug unit for 30 mins, then try again
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer gives F50 error. I've taken top off and
Press pause cancel once and that should do it. If not the repair manual advises calling for service. Lets see what the F50 is...hold on...Motor stalled, rotor position sensor detects no motion from the tub, does basket move freely? If basket moves freely see test#3 in the repair manual HERE
The manual gives readings to verify and has a long detailed complicated set of IF's for this machine. Good luck
Dl error will not clear
My Whirlpool cabrio is making a humming noise an the water filled the tub but wont drain i tried pressing buttons but no luck please help,how do i reset it
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
CABRIO WASHER
DL or F 83 is a door lock issue. Make sure the light is off before opening the lid and also check where the lock is for build up a gunk.
Aug 03, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code dL
its a door lock faliure all the error codes are in your use and care guide
Mar 25, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
235 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
