Question about Panasonic SC-HT690 System
Panasonic SA-HT690 tray won't open. There are no discs in the player, so nothing is stuck. After turning the unit on, I get the message "TRAY INIT" followed by "PLEASE WAIT" followed by "OPEN". I tried unplugging and plugging back in with no result. Someone please help!
  • Aubeckysue Dec 12, 2008
    When the unit powers up, it gives the same message. We were told by Panasonic support to take it in to an authorized service center.
5 Suggested Answers
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
Raveler
  • 36 Answers
SOURCE: infrared receiver
On page 14 of the Manual, it shows a diagram of your receiver. The infrared receiver is number 44, labeled "Remote Control Signal Sensor"
Posted on Jan 01, 2008
SOURCE: Panasonic SA-HT700 Home Theatre - Tray won't open
i have the same issues. Just took a screw driver to the four sides and opened it up. Took 5 mintues. Pulled them out.
Posted on Jul 10, 2008
  • 208 Answers
SOURCE: Tray won't open!
Hi, not being too familiar with this model ( i.e. whether a single disc or 5 disc changer). it sounds like the CD player section is trying to find home position and will not continue until it has done so. It is very likely that there is a disc in the mechanism and depending how competent you are with a screwdriver, you may be able to release the disc either by removing the top cover or check on the underside of the machineto see if there is a hole in the bottom where you can wind the cd mechanism to the eject position.
Posted on Feb 07, 2009
My SA HT 730 displays INIT on main unit and tray will not open. Can you help me? I love my panasonic.
INIT = Initiate, reason why you cannot open it is because it is having an error starting up and it is not completing
Oct 20, 2014 | Audio Players & Recorders
Panasonic SA-PT460 disc tray don't opening
The tray mechanism tracks may be binding or the mechanism may lack sufficient power to move the tray.
Dec 30, 2013 | Audio Players & Recorders
Panasonic Surround Sound system Displays "INIT" and Disc tray will not open
it is the problem of cd changer mechanism and company have 1000 reasons to blame the user.
May 31, 2009 | Panasonic SC-HT930 System
Tray won't open!
Dec 29, 2008 | Panasonic SC-HT940 System
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Panasonic SA-HT692
that just happened to me last night. do you know if there is a disc inside the player? it's possible it is stuck and preventing the tray from opening.
Jan 04, 2008 | Panasonic Home Theater System System
Init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Sep 01, 2007 | Panasonic SC-HT670 System
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
Nov 19, 2006 | Panasonic SC-HT680 System
Panasonic SC-HT690 System Logo
259 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
