Red screen on vizio
I have a Vizio 47" LCD, and I was watching tv and changed the channel and the screen went dark red. there's sound, i checked all the cables, but i have no picture. any ideas?
  • rocktsteady Sep 21, 2008
    ok, so apparently it only does this in HDMI from the cable box to tv. when I plug the coax directly into the tv it works fine.
  • 65 Answers
SOURCE: Vizio 52 Red dots
It sounds like you have a defective LCD panel. This is more common with the plasma TVs. Are you sure it's an LCD?
Posted on Aug 01, 2009
moorah1
  • 181 Answers
SOURCE: My 52" Vizio LCD (2 yrs old) has power but blank screen
Looks your power supply quit. Get a new one from vizioparts.com might cost a buck and a half,plus an hour of labor, but 52"? deffinetly worth it! Vizio is good on parts. Make sure, have your serial# ready. some sets have been modified within a year, might get a wrong part without ser#.
Take care.
Posted on Jan 23, 2010
SOURCE: Vizio 47'' LCD HDTV (Model SV470M). This TV is
I have been having the same problem!! Did you get a solution? Thanks for the help!
Posted on Feb 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#$
Posted on May 27, 2011
ganelon76
  • 11 Answers
SOURCE: vizio 48 flat screen has sound, picture will not come on right away
What cable is being used? Often times there is a few things that could effect the picture and causing flicker. If you are using an HDMI cable, or the hdmi plug on the box or tv, you could have that problem. Because the picture is digital, you don't get the snow and lines we were used to. Because the cables are so stuff, often over time they can stress and pull on the plug and cable. Try a new cable, if that does not work, try another hdmi input on the tv. If that fails then try a new cable, like a component cable or RCA. If none of these work and you still have this issue with the box then most likely it is the tv or the box. Swap out a new source, and start this process all over again. If you get the same result then it is the tv. If it works with the same cables, then it is your box. Att will send you a new box if that is the case. If it is the tv, call Vizio. Warranty or not call them. If you are sure you are out of warranty, play dumb, be vague but nice. Often you can get someone out there still at no cost.
Posted on Oct 18, 2012
Vizio 47
It sounds that the main board has got faulty. Seek check support.
Jun 07, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
We just purchased our 47" vizio television today.
i recommend not to fix anything by yourself since you bought new and the tv is under warranty. please contact authorized service or seller first.
Feb 27, 2011 | Vizio VO47L 47 in. LCD TV
Vizio vo47L 47" LCD. No
2. Power Supply
3. Backlight
Thanks!@#$
Feb 04, 2011 | Vizio VO47L 47 in. LCD TV
47" vizio died
Very high failure rate on this brand. Even after repair, something else will fail. Cut your losses and buy a brand name set.
Mar 25, 2010 | Vizio SV470XVT 47 in. LCD TV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Black Screen, Audio only , TV will not turn off
back light out,panel defective.no fuse will correct your problem.panel is bad.
Aug 19, 2009 | V, Inc. Vizio P50HD Plasma Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
My 47 in vizio lcd tv. the zoom/widescreen function will not change to fit the full screen unless its an hd channel
the LCD TV is overheating. Solution A) allow air circulation. B) set up a small fan behind the TV C) once the set is cooled down save your preferences
Apr 03, 2009 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
1,184 people viewed this question
Top Televison & Video Experts
