Question about Tomtom GO 910
My Tomtom 910 is having charging issues.
Hi, my name is Evan. I have a go 910 and the little rubber thing on the back fell out and I lost it do you know where I can find one of those. When I go to charge it wont charge properly and unless I push down on the unit on the charger? I think it might because of the missing rubber thing. It's real loose and doesn't stay together. when u pick up the unit. I just bought a new charger hoping that would be the problem but it's not.
The green light comes on. I did the reset thing with paperclip on the back. It will come on for a split second but shut off because of a low battery. Is it possible to get viruses on these things? I don't know if this was a coincidence or not, but I download some free voices off of Tomtom.com and that's when it seemed to start not charging properly.
If you have any suggestions that would help.
Thanks Evan
  • 5 more comments
  • Evan Reichley Sep 21, 2008
    Thanks for your input. I charged it overnight as soon as I bought a new charger. It didn't charge unless I put pressure on the unit the mount. There must be something loose inside the Tomtom connection that connects to the mount. Maybe the two fans on the back that lock the tomtom to the mount are worn out or something with thenmetal plate. would cleaning the connections with Alchohol make a difference?
    Thanks Evan
  • deadbug4ever Oct 07, 2008
    I have the same exact problem! It's very frustrating and I cannot drive while pushing the tomtom down. I need help!
  • dickiealan Oct 14, 2008
    my tom
    my tom tom 510 is having charging issues it is not charging even know the green light is on , it will only charge when i press down on it
  • thetrain2 Jan 06, 2009
    I have the exact same problem to a T. My guess is it comes from taking it off the car mount incorrectly (blaming the wife). I'm hoping someone posts the correct way to resolve. Ship to TomTom maybe?
  • balimanohar Jan 25, 2009
    My Tomtom doesn't charge . Light comes on momentarily if you apply pressure on connection (in car as well as on direct charging at home). It seems as if the connection is loose or that the battery is dead.
    Many thanks
    Manohar
  • rsosilva
    rsosilva Aug 22, 2012
    mee too the same problem.
    Problem Solver:
  • 6 Answers
I have a Go 510 from 2006 which has the same form factor as the 710 and 910. Mine stopped charging 2 years ago. It was out of warranty so I took it apart and replaced the battery. It worked fine until the new battery drained. Recently, I took it apart again and inspected the contact strip which is mounted to the bottom of the motherboard. I determined it was just a compression fit by carefully prying with a fine screwdriver. I pulled it off and found carbon deposits between the contact strip and the motherboard. I lightly sanded the contact areas and then reassembled. It charges fine now. Today I called TomTom to get a replacement rubber docking enabler but they no longer have them. I made one from an ear plug; it works better than the original rubber docking enabler.
Posted on Sep 21, 2012
  • jimgnc Sep 21, 2012
    In addition, I used a 0.0050" drill bit with dremel and drilled into the mounted contact strip. I then screwed eyeglass screws into the drilled holes to make the connection tight. I should have included that.
    Novelist:
  • 158 Answers
Hi Evan,
The rubber bungs often come out but it doesnt usually effect the charging although the rubber bung is there to help reduce vibration when used with a mount in a car. I have had many 910's here in the past with the bungs missing but never had any problem with them latching into the mount. I would think your problem is either some other plastic part is worn or broken. However , if you feel that the problem is the bung then I would go with your instinct but you might have to find something else to fit in the hole as parts are not readly available for TomToms unless you buy a whole unit thats faulty to use as parts / spares. Im'e sure something could be made to fit possibly part of an eraser or similar rubber part. You might also be able to use a small rubber cable grommet or similar.
As far as I know , it isnt possible to get a virus on to the TomTom as such but it is possible to get corrupted data on the hard drive ( or SD card with other models ) especially if you download things such as voices etc. I have had TomToms here were owner has downloaded comic voices and the files have caused very strange things to happen with the TomTom. I even had one where a voice file was making it look like the screen was damaged , so , your'e correct in thinking that way. In your case though , I doubt if the dowloaded voices have effected the charging , its more likely the poorly fitting mount thats casuing your problems.
If you manage to get the green light on ( this only shows power is going to the TomTom , it does NOT confirm charging ) then leave it for a few hourse before attempting to turn the TomTom on as that will ensure a resonable amount of charge especially if you battery is very flat.
Hope this helps . ( please rate the above reply if you think its helpful in any way )
Good Luck
Posted on Sep 21, 2008
  • Ken Roberts
    Ken Roberts Sep 21, 2008
    I think cleaning the contacts might help but you will need to eb careful not to bend them or move them out of position.
    Looking at your TomTom underneath where the mount fits you should see 2 small plastic lugs sticking out at each end of the connector . One at the round external antenna connection and one at the other end. Also at the front of the slot ( towards front of TomTom ) you should see 2 further plastic lugs and these should move out towards the sides of the TomTom when the release button is pressed on the front. If any of these parts are worn or broken then the TomTom won't lock into position. I have taken a photograph shown below ( incidentally this one locks on the mount OK even though it has the rubber bung missing ) so you can check your against this one to see if your plastic lugs look the same .
    Regards homemender
I have a 910 go too found that where the connection meets from the charger to the tom tom the connection inside the tom tom has broken off from the board slightly. found the same problem wont charge and will only turn on with applied pressure to the charge dock. i took mine apart cause it was pissing me off, and that is when i found that the solder contact was broken from the tom tom hanging from my windshield and bouncing around from bumps and it ended up breaking the contacts on the board for the charging hook up.
Posted on Jan 22, 2010
  • 4 Answers
Its a mega fault they know about it but they try to deny it.the 910 is ****!!!!!!! iv had 2 the first had this fault went in for repair 3 times tey finally replaced the unit now its started again.the lad on the phone admitted they know they are ****(as is their customer service) we should all demand they repair these free of charge.they have sold the thigs faulty!! dont be fobbed off by them telling you you need the bung.thats **** it does nothing to improve charging and neither does a new mount
Posted on Feb 05, 2009
Hey, i am having the same kinda problem with my (new) GO 910. I gave the device to a friend and i think he undocked it the wrong way, the green light is burning but it will not charge. It only chagres if i hold it wit the dock in my and and force it a little to the right in the dock. I see that when i go to the status window where you can also see the state of the battery and a summary of your route. then it say "charging" under that little battery icon. I really don't liked the dockkingstation from the beginning. I was thinking it looked to fragille. and now it hhas serious problems... My question is, if this is the weakest part of the whole GO 910... I also ad problems with the HD because it froze the very first time i docked it to thhe computer, i was able to fix that by having the GO 910 do a CHKDSK /F
I personally feel the TomTom GO 910 is a bad thing to have
Posted on Sep 22, 2008
On the windscreen mount there is a charging point. Inside that point should be a gold looking pin. I bet it has broken off.
Posted on Oct 22, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
The fault is the rubber bung or as Tomtom call it "Rubber Docking Enabler". This little rubber bit ensures a good connection between the mount and the 910 thus ensuring charging whilst connected. this extract was taken from someone elses contact with Tomtom customer services on the same subject:
("We apologize for our previous miscommunication. In fact, we do have these "rubber docking enablers" available and can provide you with a replacement. This miscommunication was caused by an internal misunderstanding, for which we apologize.
Two "rubber docking enablers" are on their way to you today. Please let us know if we can be of any further assistance.
With Best Regards
The TomTom Customer Support Team")
Regards
Chris Ritson
(Chrisr01)
Posted on Nov 20, 2009
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
Hi my tomtom 910 go wont switch on ], but when useing the charger the little green light lights up and will stil not switch on ive tries the hard resetting and does not work
I've had a similar problem on 2 TomTom 910s.
First, try holding in the reset button while holding the power switch down for 5 seconds.
If that doesn't work, let it charge for 12 hours and while it's still charging, hold the power switch down for 5 seconds.
It worked for me on both
Good luck
Jun 07, 2009 | Tomtom GO 910 GPS Receiver
Have TomTom 910 Having Problems Charging it.
The 910 satnav/mounting interface is dreadful- it is the cause of half the problems on this site! You can order the battery on the net. Google VF5 or Samsung ICR18650-24. To replace, strip off rubber strips. You need a mini star screwdriver, carefully pull unit out of cover gently levering at the side. Carefully observe plastic carry through which acts as button on the front and base clip underneath- this must be reinserted correctly. It is a vital part of the structure- observe it carefully! Remove upper small PCB and large PCB after removing 2 electrical connectors. Battery located under PCB. Dispense with rubber mounting. Reassemble carefully battery holder (loosely until you have placed previous plastic carry through). Tighten battery holder to hold plastic strip which must be located over mounting bracket, carefully reinsert both electrical connectors (different sizes), reattach large PCB then small one, then screw back in cover. It is likely you will then be stuck on initial screen with unit not booting correctly. You must then do software resets (opened paperclip inserted into invisible hole next to connecting strip at back). It is likely that you will have to connect to Tom Tom HOME to do this. I failed here as the darn unit will not connect to my computer.
An awful piece of equipment- I have gone Garmin!
Mar 18, 2009 | Tomtom GO 910 GPS Receiver
Replace the battery for tomtom 910go
hi take out the screws from the back x4 to get to them lift the ends of the rubbers ,once you've done that lay it flat on its face and lift the back it should slide out .now you have to unscrew a couple of pcb(printed circuit board),remove them and voila your battery you can buy it on ebay and matter of plug in plug out . hassan
Jan 22, 2009 | Tomtom GO 910 GPS Receiver
Thanks for the input.
hi, Check the photo below to see if your plastic lugs are in good condition . If they look OK then it is possible you have a bad contact to the pins or maybe even a bent pin. be careful though as the contacts are very easily damaged if you go prodding around.
Sep 21, 2008 | Tomtom GO 910
Not charging
it's not replaceable you have to send it in.
Jan 30, 2008 | Tomtom GO 910 GPS Receiver
My unit will not turn on
if you have previously used the reset button ( or maybe even if you have never used it ) , make sure the little rubber cap that covers the button is allowing the reset button to spring back up. my reset button was being constantly held down, and quite possibly was causing an intermittant reset press during driving. take a flashlight and check before sending it back/in for repair. when depressing the reset you should feel a very small click, if you don't feel it, then your button is stuck- use a needle to move/remove the rubber cap and allow the button to return to its unpressed state. hope this helps somebody out there...
Jan 28, 2008 | Tomtom GO 910 GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 Logo
3,083 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
