Question about Check Point Network Adapter
Bunker hill safe
I HAVE A BUNKER HILL DIGITAL SAFE. THE KEYS ARE LOCKED INSIDE SAFE AND I DO NOT REMEMBER THE COMBINATION. HOW CAN I GET THE SAFE OPENED?
  • 4 more comments
  • anosognosia Nov 12, 2008
    I have a bunker hill safe.  Keys are locked inside.  I enter the code and then "B" and get the subtle click and lights flash white and quick green/red, but the safe does not open.  Please help.
  • Anonymous Nov 15, 2008
    same, how do i do it
  • midwestpools Mar 11, 2009
    I have a safe at work and the key pad is worn out or gone and I don't know where the key is unless it is inside the safe and the safe is locked. Please Help me. Thanks Mary (Midwest Pools) Please call me at 863-655-9100 or email me at midwestpoolsfl@yahoo.com.
  • fiestafrog May 11, 2010
    I have the same problem! I like the hanger idea! Where is the button located relative to the buttons on the front? Does it just push in like you were pushing on the back of the front buttons? Is the a certain key it is behind for reference? I cant remember what the button looks like!
  • Gary Stewart
    Gary Stewart Feb 21, 2013
    i have a 95824 gun safe, key code is missing and batterrys are dead, combination is laying inside safe, what can i do?
  • Cathy Volner Sep 05, 2017
    I have a bunker hill safe and lost combination 91006 can someone help me tks
    New Friend:
  • 3 Answers
I had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
  • 1 more comment
  • Jeffrey Hicks Nov 27, 2012
    iroc357, You rock. Thanks so much. It worked like a charm. I put a extra long pencil in one of the wall mount holes and hit the reset button, the yellow light came on, I changed the code. Then I put the code in the second time and the green light came on and I opened it. I have a friend that is dying and he could not remember where the keys were for the combination. He asked me to see what I could do and thanks to your he is able to do what he wants with his valuables before that happens. You made him a happy man. Thanks
  • scott jones Apr 23, 2014
    Brilliant! Absolutely Brilliant!!!
    Brilliant! Absolutely Brilliant! (Love the McGuyver ingenuity!)
    Problem Solver:
  • 7 Answers
Call 1-800-444-3353 (Harbor Freight Technical Support and Parts).
Give them the model number of the safe and the key code that is etched on the front of the key slot.
If you cannot find the key slot, it is hidden behind a plastic panel, located right next to the key pad.
They will charge about $2.00 per key, and it will take about 6-8 weeks to get it.
It is resourced from outside of the US. (go figure)
Posted on Jan 06, 2009
  • Luv_Hertz May 09, 2011
    I followed Lone_Star_38's advice and had replacement keys in 3 Weeks.
    Date: Late April 2011.
    Problem: I had locked 1 set of keys in both of my Bunker Hill 91006 safes. I had the other keys on a keyring, and then lost the entire keyring. The batteries died in both safes, and I could not open them.
    Solution: I called 1-800-444-3353, and was on the phone with a guy for about 15 minutes. One problem I had is that one of the hand-written key code numbers was scibbled poorly, and I couldn't tell whether it was a 5, 8, or 9. I asked the guy on the phone to order me 4 different keys, one for the "known" keycode, and 3 to cover the one with the unknown/blurred number. Cost was $3.24 for each key.
    About a week later, a lady named "Ellen" from Harbor Freight called my house to confirm my intentions. I took pics of the 2 keycodes, sent them to her, and even "they" couldn't figure out the blurred number.
    Bottom Line: Harbor Freight's service on this matter was outstanding! I got my keys in 3 weeks.
    Lessons Learned: Don't lose your keys (duh!). Pay attention to the "low battery warning light" on the front of the safe.
    Other tips: The plastic cover that hold the batteries in place on the inside of the safe door is prone to popping off. Use duct tape or something similiar to tape that cover shut so the batteries don't fall out after you shut the safe door.
Maybe, try going to harborfreight.com, they are about the only ones that sell bunkerhill products. obviously look up safes and if you see your model, click on it, follow the info down and you can download the product manual.(you must have adobe acrobat reader. i hope this info is helpful.
waynetj@bellsouth.net
Posted on Mar 06, 2009
I have a bunker hill safe and i lost my keys and forgot my code. This is what i did. Turned safe over and drilled next to the hole for the floor mount to make opening wide enough to put my recipricating saw in it. Then i cut 3 sides to a large square patern. Then i pulled the metal back and put my hand in to push button to reset button. I pushed the metal back to its place and took it to a welding shop and he welded it up for $10.00. This safe is as good as new and the bottom is never seen, still looks new and is fully functional. Hope this helps. If you dont want to cut out bottom. Drill out holes for floor mount a little bigger and look for reset button using a hanger.
I have a bunker hill safe 91006 and obviously have a homemade handle. I want the actual handle for this safe and I can't find one !! Can someone plz tell me where I can find one?? Bunker hill doesn't sell replacement handles ): message me anyone for ideas 317-992-3133
Posted on Dec 03, 2015
I have one of their safes too. For technical questions or replacement parts, call 1-800-444-3353.
Posted on Jan 28, 2011
I enter my code on the safe but it well not let open it. I have to use the key to open it i have replace the batterys to see if that works. The pin on the switch is not droping down to let me turn the handle when i enter the code .
Posted on Jul 23, 2010
The safe is a Bunker Hill Digital Floor Safe with the following number JH0525710Item 45891 SKU P45991 I lost the code several years ago and don't have a key. How do I open the safe?
In the absence of a code and a key you can't. If it were easy to get into a locked safe, there would be no point. They exist to stop exactly what you are trying to do.
It appears to be a Harbour Freight brand, so you will get no help there.
http://www.ehow.com/how_6546958_open-hill-digital-floor-safe.html
This shows it is Harbour Freight and specifically says they don't supply replacement keys.
Owner's Manual & Safety Instructions
pdfstream.manualsonline.com/9/9e66a90a-2061-4a6f-be5c-10125e503262.pdf
Visit our website at: http://www.harborfreight.com ... To ensure security of your safe, Bunker Hill Security ... Only use this Safe on a stable, level, clean and dry.
Get a locksmith to drill the door off and get rid of it.
Feb 02, 2017 | The Computers & Internet
I have a bunker hill digital floor safe and the
Get a locksmith to make you another key. Then put it somewhere else besides in the safe.
Oct 10, 2014 | Computers & Internet
My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
Jan 30, 2010 | Check Point Network Adapter
I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Nov 15, 2009 | Sentry Fireproof Safe
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
Aug 06, 2009 | Check Point Network Adapter
Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
May 16, 2009 | Check Point Network Adapter
I have a bunker hill safe digital, and battery is too low to open the safe and cant find my key, probably inside, any suggestions
If you have the small electronic Bunker Hill safe with lost keys and dead batteries, this is a potential solution... Take a hammer and strike the top of the safe while attempting to open at the same time. You may need to place on object on top of the safe such as a flip flop shoe to strike with hammer to smooth out the pressure when striking. It should pop open after several attempts.
Jan 25, 2009 | Check Point Network Adapter
Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
Nov 21, 2008 | Check Point Network Adapter
Check Point Network Adapter Logo
22,665 people viewed this question
Top Check Point Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Gil Shultz
ray gallant
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
