Install the downloaded driver. There's an option if your machine is connected on a network or directly connected to a computer using USB. If you choose connected on a network, you should manually set the IP address. If you choose USB, the driver will detect the machine automatically.
1) on copier you have a button add. functions-something like * 2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett. 3) try to find report sett. then OK 4) you must enable the RX REPORT than OK
1)Press the Additional Funktion button.
2)Press the arrowkeys untill 6 TIMER SETTINGS is displayed Press the OK KEY
3)Confirm that DATE TIME SETTING is displayed and press then the OK key
4)Change the date and time
Press "Additional Functions" button. <common settings> should be displayed, if not press the "+" or "-" button until common settings is displayed. Press "ok". Press "+" or "-" button until "Audible Tones" is displayed. Press "ok". Walk through this submenu to locate the fax volume. Press "ok". Adjust as needed. Press ok. Press stop to exit settings mode.
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
Check view setting button to see if any jobs are pending if so you can clear them in there, try unpluging the machine for a few minutes if none of this work it could be the main board
