Question about Bosch Washing Machines
Machine keeps giving error message that door is open or cloths are blocking when this is not the case and won't start
  • 958 Answers
You might have a defective door switch. this is the part that locks the door and sends a signal to the processor to say that the door is already closed.
check also the wires that goes to this door switch. it could just be loose connection.
tnx 4 using fixya,
drcool
Posted on Sep 20, 2008
Cabrio washer door won't open!
if you plug it back in.... set at any cycle it should release then unplug asap. the aggitor/drum belt is what you are smelling.
Feb 14, 2018 | Whirlpool WTW5700XW Cabrio HE Washer
My Samsung Front Loader (WF410ANW) door lock won't open. I have replaced it 3 times. Every time it lasts about a week and I get the LO error message. I would like to know how to bypass the door lo
You can short the door switch and it will stay activated BUT the DANGER is that it will be available to be opened at any time specially after the water has loaded and if you accidentally open the water and clothes might flow out.
Jul 03, 2012 | Samsung WF410ANW Washer
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
