Question about Logic Soundlab PLX-520 Car Audio Amplifier
Help I need to know what size fuses does is take
Location of fuse box
There is no way on earth to answer your question without knowing what year, make and model vehicle you are asking about. Also, You ask what size fuse. There are many size fuses. Are you asking about interior lights, signal lights, tail lights, stereo, a/c or what?
Nov 08, 2014 | Cars & Trucks
What size fuse do i use in my amp
I would highly replacing it with an identical one.
What is the question? More information is needed before somebody can help you.
May 12, 2014 | Soundstream RUB1.700 700 watt 1 channel...
What does the fuse look like for 2004 mercury mountaineer
Sounds like you need more help than just knowing the shape. Go online and look up fuses at a autoparts store.
You need to know where the fuse is, and what size is proper. Replace with identical factory Rated size. Not bigger or smaller.
What you would do is inspect the part that does not work to find out why it broke the fuse. Only rarely would there not be a reason.
Jan 08, 2014 | 2004 Mercury Mountaineer
Peg Pergo Turf Tractor fuses
they dont have fuses, they just have thermal switches which you can bypass just for troubleshooting, please contact me if you need help troubleshooting
Sep 08, 2012 | Peg Perego John Deere Turf Tractor
Size of fuse for Ultimate PA2204
O SO U JUS NEED LIKE A FUSE THAT IS ABOUT 20-40 AMPS
Mar 20, 2009 | Car Audio & Video
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
What size fuse does a RCA PS27113 use?
Where the fuse are put it on the board get the capacity always be 150 volts 5 ampers
Aug 16, 2008 | Proscan PS27113 TV
Car alarm in-line fuse
What type of alarm system is it? The size of the fuse varies slightly depending how extravagant the alarm is. You could try to low ball it and if it pops the fuse then get a slightly bigger one. You might start out at 15 amps. BUT, if you can tell me the make and model of the alarm then I might find out the correct size. I hope I can help.
-Andrew Hawkins
Mar 31, 2008 | Car Audio & Video
Logic Soundlab PLX-520 Car Audio Amplifier Logo
19 people viewed this question
Top Logic Soundlab Car Audio & Video Experts
Tygh Duval
Tygh Duval
Bill Boyd
FastHarley
FastHarley
Are you a Logic Soundlab Car Audio and Video Expert? Answer questions, earn points and help others
