I have an rca tv that turns itself on and then continues to channel surf. It will not allow me to turn off with remote or on the tv itself.I tried unplugging and replugging with no success.
  • 8,617 Answers
Whats the model number of your RCA and I will try to assist you. Sounds like you need a signal board.
Posted on Sep 21, 2008
42 inch rca turns on and off when on every button on remote changes chanel and the buttons on the tv itself do not work at all ive unpluged them no change it just continues channel surf on its own
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Dec 18, 2015 | RCA Televison & Video
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Volume & Menu screen flipping out
Replace all of your contact switches on front panel board power/off/on vol- vol+ ch- ch+.
Jan 05, 2009 | RCA HD52W66 Projection Television
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
RCA 52
the chances are you front keypad has malfunctioning i see this alot at the shop. if you can remove the front panel and remove the keypad cuircit board and turn it on with remote then it will definatly be the keyboard generally i suggest replaceing this cuircit l
Oct 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA 27V412T
I repair these for a living and usually this is caused by the "tact switches" (buttons essentially) on the main pcb. This can be fixed easily by someone who is familiar with working with soldering small parts by changing the switches. The problem is most service shops must charge $60-$100 for bench time on a repair like this which is hard to spend with the replacement cost being so low on this product.
Nov 23, 2007 | Televison & Video
Rca model P46920BL
This could be a remote problem, try it while the remote it out of range/no batts if so just replace the remote. Pull the batteries out of the remote - fixed? Then: Check the switches, sometimes people clean the set and fluid drips down corrodes the hidden switches and some components near them. If not that check continuity of the switches Another thought, is if you have compact floresent lamps in the room, these can cause some IR interference that can trigger events on your remote control input. last, does anyone near you has the RCA TV? mybe other remote is effecting your TV...
Nov 10, 2005 | RCA P46920BL 46" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
