Question about Sony KP-61HS10 61" Rear Projection Television
Projection TV cold convergence
My Sony KP-61HS10 is out of convergence when I turn it on but gradually comes into convergence as it warms up, but that takes 15 to 20 minutes of watching it out of focus. If I use the Flash Focus to get it into convergence while it is warming up, then it's out of convergence once its warm. I've had two repairmen out to fix it while it was in warranty and they did nothing. I've lived with the problem rather than take another half day off work to meet with another repairman. Now the warranty has expired. What to do?
  • Jim Rogers Oct 22, 2008
    Exact same problem and response. Have not called repair yet, but will wait for responses here.
    Sergeant:
  • 233 Answers
First things first... check all the solder joints on your convergence IC's - if they are fine, then the reason the color has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Posted on Dec 21, 2008
My KP-62HS10 sony tv got picture smear and cook on right sight. i think some electronic part burn out ?
Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like?The tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Picture seems 3D an display showng duplicate
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board,must require changing it 2 STK convergence ICS and some or all it resistors too.These parts,must be change to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 13, 2010 | Sony KP-61HS10 61" Rear Projection...
The colors are out of alignment on my sony kp-61hs10 how do I fix it?
Ur convergence is dead.Must know how to solders?Must replace 2 STK convergence ICS,and some or all it resistors.Tries these websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 18, 2010 | Sony KP-61HS10 61" Rear Projection...
Tv looks like the edegs curve and is blury
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP61HS10 Convergence issue
u may purchase service manuals here/
www.servicemanuals.net
Jan 09, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
141 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
