Where do I buy IC chips for my Mitsubishi 65 inch tv? 65909 is the model #.
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 142 Answers
You should be able to find anything parts related on E-Bay, type in the info you put in here and do a search, you should be able to find it rather quickly
Posted on Sep 20, 2008
Mitsubishi 65 in Model 65909 DM Board replacement
There is not a replacement board available from Mitsubishi; you have two choices depending on problem: either a repair kit (widely available on the internet) or Contact PTS Electronics who will repair or rebuild it for you.
If you have questions let me know.
SD TECH
Nov 16, 2011 | Televison & Video
I have a convergence problem on my Mitsubishi 65 inch rear projection tv (model number WS65511). I see red double images on all four sides. Middle of the screen is OK. Which IC Mitsubishi use STK393-110...
Your model is the V21 chassis it requires the single IC STK393-110 you will also need 2 5 amp pico fuses. The convergence repair kit is available for your model at www.tvrepairworld.com which contains the IC, heat sink paste, the pico fuses and the CD with repair instructions and other service info for that model.
Jun 10, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Hi . My name is Paul. ws65 909 is about 12 yrs old. Have a yellow swoop front top right to top left, and there is double image on screen. Any ideas how to fix? Thx
Go into customer menu and select convergence, then advanced--if as I suspect it is skewed and will not adjust it is the convergence IC this set uses.
This model is one that uses just one chip for this---STK-393-110 and part is under 15 dollars on EBAY.
Good news: I have start to finish, step by step instructions for the do it yourself person for this repair in this set.
If you want the instructions we can find a way to get them to you, they tell you everything you will need and exactly how to do the repair.
If this information helped, rate this solution as very helpful as I do this for free.
SD TECH
258ae96.jpgIC Chip used in model you indicate you have.
Sep 05, 2010 | Mitsubishi WS-65909 65" Rear Projection...
65" rear pro. Convergence IC Repair
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Sep 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
After about 3 minutes of my tv being on my convergence goes out of wack. I've tried to line it up but not all the lines will move back. Plus it works if I turn it off/on but only for a few minutes.
WS-65907 is a Mitsubishi 65 inch tv--it uses two STK-392-570 Convergence IC chips---I have repaired hundreds of these sets with this kind of trouble---the 570 Ic can be intermittent---You can buy two of them on Ebay for under 13 dollars plus shipping---this should be instantly fixable in your home---Get someone who is familiar with this kind of set; the center board inside has both of the IC chips on it; it needs to be removed and both IC chips replaced--all that is needed after that is to adjust the set with the Mitsubishi remote control---usually the whole repair takes about a hour in someone's home---I know----I do this on a regular basis---if you have any questions or need direct help of any kind contact me at my email---- etower.766@netzero.net---if this has been helpful I would appreciate a vote from you here. Steve
Aug 14, 2009 | Televison & Video
I am buying a Mitsubishi WS-65909 from aprivate seller and I read
You have been mislead. I just checked the service manual and that model does not seperate in two like some Mitsubishi's do.
Apr 18, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Projection screens interchangeable?
it should work fine, its worth a shot
Apr 12, 2009 | Hitachi 65F59 65" HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
