Question about LG WM-2277HW Front Load Washer
Gasoline smell in the washer
My husband washed two towels that had some gasoline on them from a boat motor he has transferred. Now the inside of the washer and anything we wash smells like gasoline, what can I do to get rid of it. Should I run a load with bleach or should I wash the inside of the drum with vinegar???
Please help, the washer is new.
  • 706 Answers
White vinegar is NEVER a bad choice and I would use that.. start a wash ( without clothes) and when the washer fills with water.. stop it and open the door... add a cup or two of white vinegar and let it cycle thru ..When completed, leave the door open to allow the inside to air out... You can also use a product sold at Home Depot and other home improvement places called AFRESH ... hope that helps...
Posted on Sep 21, 2008
How to get fish smell out of dryer
Tomato juice removes skunk stink from your dog, maybe put some on a towel & run it through a cycle.
murf427
Aug 01, 2012 | Whirlpool Dryers
My washer stinks
Hi, problem occurs due to cool washes(i.e. 40c and under) not destroying bacteria from clothing/detergent which then breeds inside your machine, therefore creating a sometimes sulpherous or musty smell.
I would advise you to regularly do a hot wash(minimun 60c) with an old towel, soda crystals and washing machine bleach i.e. vanish, ace etc with an old towel in the drum to move the mixture around. if you keep up with this the smell will eventually go away.
You can buy limescale/detergent removal powders which will do the same job.
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Gear Lube leaking from Prop
Keep an eye on it and put a bucket with paper inside under the motor. You want to know whether the oil is burnt oil from the exhaust or gear lube. You should be able to tell from the color of the oil. Its kind of like soot in a chimney, the exhaust goes through the prop with the oil you added to the gas.
Jun 27, 2009 | Light Outboard Motor Boat Bass Fishing...
LG washing machine has AWFUL mildew smell
Causes of grease, slime and black mould inside washing machine Your problem has nothing to do with the washing machine, any washing machine - even the best can be affected. I suspect your problem is mostly related to using liquid detergents that contain no bleaching agents
Jan 13, 2009 | Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Stinky towels
Mildew odor in towels in almost invariably being transferred from the washing machine. The clothes washer must be cleaned first then clean the smelly towels and laundry. To compare washer cleaners watch this video of Affresh and Smelly Washer...
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 19, 2008 | Washing Machines
Foul smell
More then likely you're still using too much detergent and liquid softner. Front load washers use about 1/10 the water of a top load so all you need to use is about 1 tablespoon per load of soap and softner. If you use any more then that it builds up inside the tub behind the drum where you can't see it and starts to smell. Running the machine empty about once a month with just bleach will help stop the build up. If you do this and see soap suds that's left over soap coming out. If you see suds run it again and again until the water stays clear and you odor problem should be gone. You can go back to colored towels.
Feb 19, 2008 | LG WM-2277HW Front Load Washer
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
LG WM-2277HW Front Load Washer Logo
497 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
