Question about Lexmark X5470 All-In-One InkJet Printer
HOW TO REFILL LEXMARK X5495 PRINTER
I HAVE TRY TO REFILL MY LEXMARK MODEL X5495 PRINTER ,BUT WAS IMPOSSIBLE. THE PRINTER DO NOT RECOGNIZE THE CARTRIDGE AND DO NOT LET ME PRINT. I BOUGHT A NEW ONE IS WORK CORRECTLY. WHAT CAN I DO TO BE ABLE TO REFILL AND USE MY PRINTER.
TITLE; HOW TO REFILL LEXMARK X5495 PRINTER
  • seamus007 Oct 28, 2008
    Why must an OEM be purchased. This defeats the entire principle of refilling cartridges! The manufactuer must have equipped the hardware with a progam that can be rewritten to allow for the use of refill kits. Is there an amended software package available.
  • dave28480 Nov 21, 2008
    I have same problem even after purchasing a refilled cartridge from a web supplier. Printer still thinks the refilled cartridge is empty. I have to take out and then refit cartridge and go through alignment routine each time I want to print.
  • Lexmark Master
  • 4,338 Answers
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
http://www.ink-refills-ink.com/printer/Lexmark+X5495+Ink/15981/?src=gpsearch&gpprod=Lexmark+X5495&gptype=bulk
http://www.internet-ink.co.uk/lexmark-ink-cartridges-X5495/
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 04, 2008
SOURCE:
Have a lexmark x5495 and have new cartridges. when printer is turned on, message states left cartridge incorrect.
Make sure that you are inserting genuine Lexmark cartridges and the correct versions for your model. The Lexmark X5495 takes 28/34 black or 29/35 color cartridges.
Try to re-insert your left cartridge and make sure it is properly seated in the carrier.
You can also try to reinsert your old left cartridge to determine if it's a faulty cartridge issue.
Oct 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
I have a lexmark x5495 which was working fine,then my computer got a virus so i had it repaired and since then my oprinter wont work,i have tried downloading driver but nothing happen
Try downloading the driver from the Lexmard WEB site.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Dec 08, 2010 | Lexmark X5495 Printer
Hi, I have lexmark printer, model X5495, and I am having problem with the machine. The alignment is on, and whenever I tried to make copies, the paper is all cramped up and got stuck. I cannot find my...
Try removing the cartridges from the printer. Close the cover. Remove the sheets of paper. Unplug the printer from the power source. Replug after 30 seconds. When the printer's ready, reload the cartridges. Load some paper, don't overload. Try printing again. If problem continues, I strongly suggest you contact Lexmark technical support to further investigate the problem. You may be having a hardware problem.
Here's the link for the Lexmark X5495 User's Guide: http://bit.ly/c5QWkq. Just download it and it's for free. Thank you for choosing Lexmark.
Aug 25, 2010 | Lexmark X5495 Printer
Need installation cd for lexmark x5495
You can download the Lexmark printer drivers from the Lexmark WEB site. Please click on this link and select your model printer and the XP or Vista version of the driver you require :-
Jun 06, 2010 | Lexmark X5470 All-In-One InkJet Printer
INSTALLING LEXMARK X5495 SOFTWARE. WHEN I GET TO
Make sur ethe usb is pluged in adn the printer is on. If your computer is not detectingthe printer restart the computer, if all else fails try another usb port.
please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 22, 2009 | Lexmark X5495 All-in-One &USB...
Can A Lexmark X5495 use the driver for a X5470 instead???
try it and see most likely it won't work but you could try to upgrade the software.
Jul 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
LEXMARK MODEL x5410 ON FRONT OF PRINTER; ONLY X5425 &X5495 ON CD
When you click on the big "X" tab, look at the bottom of the list. There is a line that says, "Don't see your Lexmark product listed?" Then there is a link to "See other Lexmark X models."
Click on the link and you will see the X5410 listed.
Thanks for using Fixya. A "Fixya" rating would be appreciated.
Jan 22, 2009 | Lexmark X5495 Printer
Refilled x5495 cartridge
hey jose022-it sounds like the ink on the header has dried up . Try pulling the cartridge back out and blotting it on a clean napkin .I f there isn't a small display of the three colors on the napkin , the cartridge end probably dried up before you refilled it.In this case you need to use the head cleaner kit and follow the instuctions that comes with it.
If there isn't aclear low of all three colors coming out the sensor will recognize it as only as the previous empty cartridge.
good luck !
trackrunner11
Oct 17, 2008 | Lexmark X5495 Printer
Lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Mar 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
975 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
