Question about Whirlpool Dryers
Whirlpool Ultimate Care II LGQ9558KQ! is not spinning. Whre is the belt?
  • 750 Answers
Galitbunny
Welcome to our site.
You siad, the dryer is not spinning.
Can you hear the motor?
If you can not hear it then not your door switch or the main fuse inside the dryer is bad.
You pop the top and you will see both the belt and the fuse.
Let me know how you are.
Bless You,
Huuum
Posted on Sep 20, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Top load whirlpool ultimate care II
    Sounds like something got stuck some where take off belt try to spin water pump pulley some times socks get caught if it will not turn take it out and clean it out if you can if not replace it.
    Turn transmission pulley it to the left it should be stiff but should turn by hand if not call a service provider. Look at the belt is it worn in spots cracked or show fibers if so replace it.
    Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Won't spin, won't drain
    Hi...
    If your washer does not drain, you need to check this:
    • Inspect the drain hose for kinks
    • Test the timer control
    • Test the lid switch (some models)
    • Inspect the water pump
    • Inspect the drive belt (belt drive only)
    • Inspect the motor coupler
    If it does not spin check also this:
    • Test the centrifugal switch
    • Test the water level switch
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    Good luck !!!
    Regards
    PCmania
    Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II Super Capacity Plus
    BETWEEN THE MOTOR AND TRANSMISSION THERE IS A COUPLING THAT SERVES AS THE BELT PART # 285753A REPLACE THAT WILL SOLVE YOUR PROBLEM
    Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    The motor will not spin..... can i have a diagram of a motor of ultimate care ii washing machine
    The typical problems with "the motor will not spin" is a:
    1. Lid-switch (very frequent): Will not drain, incomplete cycling, switch ultimately passes power to motor.
    2. Belt or coupling (very frequent) - Belt moves when motor spins
    3. Timer/control board (rare)
    4. Tranmission (rare)
    5. Motor (somewhat rare)
    How do you know the actual motor is not spinning? Do you mean, the tub not spinning? Do you have a noise as if the motor is spinning?
    Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
    Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
    Good luck
    Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II wont spin,
    Dear friend,
    ngfam at you service!
    You can not fix this problem your self!!!
    This sounds like it will only fixed by service then you will be happy again!!
    Yes sounds like you need service!
    Call A&E Factory Service /They service nation wide
    And are available 24/7 for making appointments!
    If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
    Happy to assist you,
    PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
    Aug 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II washing maching but will not spin.
    lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
    Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Open Questions:
    Dryers Logo
    110 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
