Question about Acer Computers & Internet
I have no sound coming from laptop.....volume turned up....computer says device working properly
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 142 Answers
Try going into your control panel and go through the Sound and Audio device icon. Once here you will look for the tab "Audio", click on that. The first section displays playback audio click on the volume button, and from here make sure, that none of the controls listed here are muted. Also make sure that all the volume controls are set up as high as possible. See if that helps....
Posted on Sep 20, 2008
My laptop have inbuilt speakers but when i switch to volume control option it dispalys a message that no audio output device is installed and sound is also not coming
Check the Sound Drivers in device manager if the device is not installed you need to download the drivers from HP Web site by using the Product Number
If you can please specify the Product Number and Serial Number of the Laptop
Jul 14, 2012 | HP Compaq nc6320 Notebook
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Dell Computers & Internet
My sound is not working
Hi dennismor884 ,
If you sound card it not working please follow the below solution :-
1 - Check if the sound drivers have been installed properly , you can do this by going to your device manager from the my computer option , all you need to do is right click on the my computer icon and then go in properties - hardware - and then choose device manager.
2 - Check if there is any icon showing ? or some other sign inside the sound and the audio devices option,
3 - If it's ok , then you need to make sure that the sound is not set to mute from control panel , you can check the master volume, the wave volume etc...
4 - If there is some problem in the device manager in the sound options then you need to resinstall the sound drivers from the motherboard cd that has come along with your laptop.
This should solve your problem , let me know in case you have any queries.
Aug 22, 2011 | Dell Computers & Internet
No sound
Here are some things to check:
  • If you have external speakers, make sure that they're plugged into a working power source and that they're turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, make sure that the cable that plugs into your computer is plugged into both the speakers and the correct jack on your computer (the jack that goes to your sound card). Most sound cards have at least three jacks. Plug the speaker cable into the line-out jack. This jack often has a symbol showing an arrow pointing away from the jack. If the jacks aren't labeled, check the information that came with your computer to see what each jack does.
    ?id=8440e487-7ae3-427b-a9b7-c861a5521758Most sound cards have at least one line-out jack to connect speakers and a line-in jack to connect an audio input device.
  • Make sure the speaker volume isn't turned down too low or muted. This is particularly important for laptops, which often have small speakers that can be hard to hear.
    1. Click to open Volume.
    2. Move the slider up to increase the volume.
      Make sure the Mute button is not turned on. If the button looks like this: ?id=6b62e2ae-431c-4fb5-8905-aaaea5b445a4, muting is turned off. If the button looks like this:?id=0f47efa2-ffcc-466d-a723-bd0ce4640578 , click it to turn off muting.
      Note
      • Some laptops have an external volume control on the outside of the case. If you're using a laptop, check the external volume control to make sure it's not turned all the way down.
  • Make sure your headphones aren't plugged into the line-out (headphone) jack of your sound card or computer (unless you want to listen with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
  • If your computer is supposed to have a sound card, make sure that the sound card is installed and that it's working properly.
    You must be logged on as an administrator to perform these steps.
    To make sure that your computer has a sound card
    1. Click to open Device Manager.‌ ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. Double-click Sound, video and game controllers to expand that category. If a sound card is listed, you have one installed. If no sound card is listed, check the information that came with your computer to see if there's supposed to be a sound card installed. If there should be a sound card installed, you'll need to install one. See Install or remove a sound card.
      Note
      • If you think you have a sound card installed but you don't see it under Sound, video and game controllers, double-click Other devices to check for any audio devices listed there.
    To make sure that your sound card is working properly
      If there's a yellow question mark next to the name of the sound card, there might be a problem.
    2. Double-click Sound, video and game controllers to expand that category, right-click the name of the sound card, and then click Properties.
    3. Click the General tab, and then check the Device status box to identify problems with the sound card.
      If there's a problem, you might need a new driver for your sound card. For more information, see Update a driver for hardware that isn't working properly.
If these actions don't solve the problem, there might be a problem with the hardware for your sound card, although in most cases sound problems are caused by missing or out-of-date drivers, or a problem with your speakers. If you suspect you have a hardware problem, contact the manufacturer of your computer or sound card.
Feb 17, 2011 | HP Compaq dc7100 Small Form Factor PC...
No sound my system
If there is no sound coming from your computer try these "simple" but common solutions first.
1. Make sure the power cord is plugged into an outlet and the speakers are turned on.
*Make sure your speakers are correctly connected to the computer.
*Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
2. Make sure your computer has a sound card and that it is enabled and working properly:
To open Device Manger...
*Start
*Control Panel
*System and Maintenance
*Device Manager
*Expand the Sound, video and game controllers category.
*Check the status of the driver and update if necessary.
3. Make sure that the speaker volume is not muted or turned down too low.
To open Volume Control...
*Click the Start button ,
*Click Control Panel
*Click Hardware and Sound
*Under Audio Devices and Sound, click Adjust system volume.
*Under Main Volume, move the slider up or down to raise or lower the volume.
If you still have no sound after checking the solutions above, you more than likely have a bad sound card.
Jul 13, 2010 | Computers & Internet
No sound in my computer and i can't figure out why
Check to see if you have the mute ticked in the volume control, your laptop may also have a volume control knob that needs turning up.
Also check the sound level is not set to minimum.
Connect headphones to the sound out connector and see if you can hear and sounds.
Open the Control Panel, Click on Sounds & Audio Device Properties, you can check on all the sounds and audio device etc.
Dec 04, 2008 | Audio Players & Recorders
Sound Device not working but everything seems to be installed and working
you might want to try going into the bios of your computer (usually pressing delete when your computer first comes on) and looking in there to make sure your sound device is turned on.
Oct 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
Sound
Try this....
Locate the volume knob (toshiba laptops normally has this volume know located on the side of the laptop). Make sure it turned on. and see what happens. Even if the sound icon in the taskbar is turned up but if this knob is not then there would be no sound at all. I am assuming that your drivers are good since you said in the device manager that all are working properly.
hope i was able to help
Apr 08, 2008 | Toshiba Satellite A75-S211 Notebook
Why our head phones on Computer are not working
Is there a switch to turn on the headphone port? Is there a control on the headphones to adjust the volume (on a volume level on the side of the laptop)? Also, when the headphones are plugged into the laptop, go into your sound settings and turn up the master volume (and wave volume if it is low.. If that works, make sure to turn it back down when disconnecting the headphones).
Also, do the headphones work in another device (stereo, etc..)?
Mar 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
