Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Bosch washing machine spin cycle is not working
  • 2 more comments
  • HatterasJack Dec 06, 2008
    We have a Siemens version of trhe Bosch washers and it has the same problem. The error code E13 has come up and the machine will not spin. It also is emitting a smell like that if lightly buring rubber or even electical insulation burning, but lightly. I have not found any solution yet. I would love to know what this is.
  • Anonymous Jan 15, 2009
    repair manual
  • clarkbeehler Jan 15, 2009
    I wood like to get a repair manual on replacing the pump
  • cwill22014 Jan 29, 2009
    The washer stops at the spin cycle and makes a humming sound. There remains some water in the washer and I cannot engage the drain cycle either.
I don't know if this will solve everyone's problem but I found the problem in my machine. I found a SHOUT color catcher stuck in the impeller of the drain pump in the bottom of the machine. If you remove the round face plate covering the drain plug and then unscrew the drain cover you can access the little pump impeller. I found the 5" x 10" color catch sheet stuck and impeding the rotation of the impeller. Once I removed it, reset the machine, reinstalled the drain cover and outer cover and restarted the machine, it worked fine.
We use alot of these color catchers and have never had this problem before. But as they say, there is a first for everything.
Steps to repair:
  1. Unplug the machine
  2. Lift an edge of the round face plate covering the drain on the lower right corner of the face of the machine. Then rotate it clockwise about 1/8 of a turn. Remove the face plate.
  3. If you are sure your machine is empty you can simply unscrew the drain plug which is a roughly 4" round plug with a handle molded into it. I had standing water in my machine so I vacuumed out the water first then held the vacuum at the opening of the drain plug and slowly unscrewed the plug letting the water get sucked up . This took about 5 minutes just to drain this drain trap.
  4. Unscrew the drain plug (if you haven't done it already)
  5. You have to fully unscrew the drain plug then pull on the plug a bit to get it to come out.
  6. Examine and remove any debris you find in the drain trap. (In my case, this where I found the color catcher stuck up in the impeller of the pump which is toward the middle at the bottom of the drain.)
  7. Reinstall and snug the Drain plug. To do this you need to properly orient the plug to get it to go in correctly. You have to wiggle it alittle as well.
  8. MAKE SURE THE PLUG IS SNUG OR IT WILL LEAK!
  9. Double-check the security of the plug
  10. Reinstall the face plate by orienting the tabs on the cover and rotate in place counter-clockwise.
I hope this helps some of you out there.
Posted on Dec 06, 2008
  • Mark Covalt
    Mark Covalt Nov 28, 2011
    I just fixed my washer !!!
    Thanks for your input. Mine had a rubber band wrapped around the impeller. That .01 cent rubber band would have cost me a $100 service call...
    Thanks so much for relating how you fixed your machine.
    Mark Covalt
    Problem Solver:
  • 5 Answers
My manuel says E-13 means too much suds or a blocked pump. The "Solution" it gives is to push any program button and run the cycle again. A door locked can be manually unlocked by removing the circular access panel at the bottom right and pulling the manual release button. Hope this helps.
Posted on Mar 02, 2009
OK, I have the Nexxt 300 series. Throwing the E-13 code. My machine is less than a year old so I called the authorized Bosch repair service. ( I have replaced pumps in washers, but hey it still under warranty).
Anyway, he checked the pump and it was clear. My machine is working perfectly. What's the solution? Unplug the machine for a few minutes. According to the repair guy more and more appliances just need to be unplugged so to reboot the computer whenever they are acting funky.
All in all this should be the first thing you try when you have this issue. After that I would go through the processes of the first solution on this page.
Posted on Jan 22, 2010
The washer nexxt 500 series it has stop spinning with a e13 does anyone know wha this is
Posted on Oct 13, 2008
4 Suggested Answers
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
My Bosch machine is not spinning properly leaving my washing still really wet. Tried cleaning pump once before and it worked but it's not worked this time round. At 1200rpm the cycle is really s
Bosch machine is not spinning properly leaving my washing still really wet This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 21, 2012 | Washing Machines
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Spin cycle does not operate
Your clutch on your motor is not working. Your clutch on your motor controls how the motor either spins or agitate.
Dec 15, 2009 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch washing machine won't spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Oct 26, 2008 | Bosch WFK 2401
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
3,401 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
