Question about Garmin Forerunner 305 GPS Receiver
Garmin Forerunner battery replacement
Hi F-Phil
what kind of battery did you use to replace the original battery in the Forerunner 305. The Garmin 361-00026-00 seems not available, at least a web search did not come up with any results.
I have seen somewhere else (http://ctorunner.googlepages.com/dismantleforerunner205) mentioned that the Forerunner 305 battery look like an IPod (generation 4) battery.  But so far I have not found any information about the size of these batteries, i.e. if they match the approx. 40mm x 35mm x 5.5mm of the original battery.
Cheers, Stephan
It's not always the battery, I assumed it was and opend mine up to check it out but the battery was OK.
Problem was the unit wouldn't start without pressing mode + reset followed by the power button.
I lifted the internal watch contact strips to put a better connection between the two halves but that made no difference.
I found that I couldn't delete all the history and the watch had recently turned itself off on a run after giving a low battery warning => the history was corrupted and caused the watch grief.
The only way I found to delete the history was to load a v 2.80 (or earlier) version of the watch s/w (current 2.90 doesn't delete history and there is no tool to do it!)
Fortunately I had a copy of v2.80 but the old version is not now on the Garmin site (that I saw).
Moral of the story, don't run your battery low for two reasons, Li-ion batteries lose capacity if you run them below ~30% and also if the watch "low battery" turns off while recording it can corrupt the history and really upset the watch.
At least I now know how to open the watch and have found plenty of possible small mobile phone batteries that will fit (Samsung have a few possibilities). The ABSOLUTE max size of a replacement battery is 36mm H x 43 mm wide x 5.8 mm deep.
If you go 43 mm wide you have to trim a couple of internal plastic ridges in the case.
Good luck and try starting after pressing mode + reset if it won't fire up then try and delete all the history.
Also DON'T run the battery low if you want it to last, Li-ion work opposite to NiCad and NiMH which should be fully discharged before recharge. You try and keep them above 50%.
Steve
Posted on Dec 25, 2009
  • faceblair Jan 07, 2011
    Had the same "could not power up problem" and suspected the the battery. Called Garman and there service person directed me to try holding the mode button and the power button down at the same time for seven seconds. It still did not power up. I then asked about the availability of batteries and was told they were not available. The service person then gave me the option to send the unit back and for $79 they would send out a rebuilt unit with a 30 day warranty. Thinking that was not a satisfactory option, I then consulted the internet and ran across the "hold the mode and reset buttons down at the same time for 5 seconds followed by the power button. Just like magic the watch then came on. In discuss I called Garman back and informed them of how unhappy I was with my service experience. The service person I reached this time first apologized for my previous experience and then to my surprise then indicated there are actually 4 resets that may
  • 9 Answers
Posted on Aug 15, 2009
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
NO life in my Forerunner 305
Try first changing the battery if you have but if not better call Garmin and let them repair or replace it if its still under warranty..
Hope that helps..........
Aug 04, 2008 | Garmin Forerunner 305 GPS Receiver
Forrunner305 battery replacement
Jim Rogers had a similar problem and on his blog, he provides complete instructions on how did it. Apparently, Garmin wants $79 to do this work - but it sounds like he did it for significantly less that that.
Check Jim's blog (by clicking) below:
http://www.jimandkatrin.com/CodeBlog/post/Forerunner-305-Battery-Replacement.aspx
If it looks too involved for you, check Garmin's "Out of Warranty page, below:
http://www8.garmin.com/support/outofwarranty.html
I hope this helps & good luck!
Nov 16, 2011 | Garmin Forerunner 305 GPS Receiver
How do i change a battery in a garmin 305
Hi David!
From your Owners Manual (Page 54)
http://www8.garmin.com/manuals/984_OwnersManual.pdf
REPLACE THE HEART RATE MONITOR BATTERY
"The heart rate monitor contains a user replaceable CR 2032 battery...
Locate the circular battery cover on the back of the heart rate monitor. Use a coin to twist the cover counter-clockwise until it is loose enough to remove. Remove the cover and replace the battery. Be careful not to lose or damage the o-ring gasket on the cover. Then use a coin to twist the cover back into place."
Hope this helps.
Jan 16, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 GPS Receiver: Is it possible to change the battery in a Garmin F...
Yes you can. Go to the Garmin Website and simply email them asking for the price of the battery and instructions on how to replace your specific model and serial number as they changed in mid year many times.
May 03, 2010 | GPS
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Replacing battery on Forerunner 305
Well it is an accumulator instead of a battery so just recharge it.
If the accumulatoris gone I think you have to use the garmin support
regards,
Ralf
Aug 11, 2008 | Garmin Forerunner 305 GPS Receiver
Battery doesen't keep the charge. I can't open the case to change battery forerunner 305
Hi Samdot,
I have just been through a similar problem through ingress of water into the device (They are not in the slightest bit water proof)
My device would power on, but only in the cradle attached to the usb and it would say the battery was fully charged after 4 seconds.
Any way, the battery can be replaced using the following method.
Take a decent, thin penknife and gently lever the top off the Garmin (follow the crease above the buttons). There are no catches to be aware of it is just lightly glued.
Once the lid is off you will be able to remove the two circuit boards (they just sit in there) and you will see the battery in the bottom of the case.
Unscrew the two small screw above the battery connections and you will be able to replace the li-ion battery which is in place.
I can provide images if that would be useful.
Phil
Jun 17, 2008 | Garmin Forerunner 305 GPS Receiver
Make sure the small prong under the battery is bent out a bit, sounds like an intermittened connection problem.
Mar 17, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
5,090 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
