Initially had trouble with sound. then went into set up menu. while in clicked on video and accidentally change to PAL which give continous screen rolover and can't get out of it. Help
Look for a "reset" selection to reset the machine to the factory defaults. Try connecting the player to a computer monitor and try to access the setup menu.
Posted on Sep 20, 2008
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
Hello, i just bought an lcd Tv converter made by manhattan. the model is 176156. the problem is in the video section, don't let me change the standards (NTSC, PAL, PAL-NC, etc) want to know if there
I think you press the wrong button that change the settings of your TV to restore it original settings kindly go to menu and find factory settings then press enter..
hope it helps..
Dec 11, 2011 | Manhattan LCD TV Converter/Tuner (176156)...
It's showing the video in a split, black and white screen
could be a pal/ntsc region code problem, either the menu setting is pal and your playing a ntsc region coded dvd or the menu is correctly set at ntsc and the dvd is pal that you are trying to play
Dave
Dec 27, 2010 | Initial IDM-1210 Portable DVD Player
How to change language display on Sony Cyber-shot
Start of Automatic Adjustment Program
Double-click the application file (DSC-T700 Auto-Adj
Ver_1.0r01.exe), and the Automatic Adjustment Program will start.
DESTINATION DATA WRITE
Note:
The DESTINATION DATA WRITE cannot be set with other
than the Service board.
1. Function of Each Button on Destination Data Write
Screen
Click the [DESTINATION DATA WRITE] button on the Main Menu
screen, and the “DESTNATION DATA WRITE” screen in Fig. 6-
1-10 will appear.
Fig. 6-1-10
1 [To Menu] button
Return to the main menu.
2 Destination Check button
Current destination setting checked when the “DESTINATION
DATA WRITE” screen started is displayed.
When this button is clicked, the destination is checked and the
display is updated.
3 Destination List
Select the written destination.
4 [Data Write] button
Write the destination data to the camera.
Japanese
English
French
German
Spanish
Italian
Portuguese
Simplified
Chinese
Traditional
Chinese
Dutch
Russian
Korean
Persian
Arabic
Thai
Melayu
Swedish
Norwegian
Danish
Finnish
Polish
Czech
Hungarian
Turkish
Greek
J1 J z NTSC
JE3 JE z a a a a a a a a a a PAL
U2 US z a a a a a NTSC
CA2 CND z a a a a a NTSC
CEE2 a a a a a a a z a a a a a a a a a PAL
CEE8 z a a a a a a a a a a a a a a a PAL
CEE9 z a a a a a a a a a a a a a a a a PAL
CEH UK z a a a a a a a a a a a a a a a PAL
E15 z a a a a a a a a a a PAL
E32 z a a a a a a a a a a PAL
E33 a a z a a a a a a a a NTSC
TH6 Thai a a a a a a a a a z a PAL
AR2 AR a a z a a a a a a a a NTSC
AU2 AUS z a a a a a PAL
HK1 HK z a a a a a a a a a a PAL
CN2 CH a a a a z a a a a a a PAL
KR2 KR a a a a a a z a a a a NTSC
BR1 BR a a a z a a a a a a a NTSC
z: INITIAL LANGUAGE
E
DESTINATION
VIDEO OUT
Default
AEP
AREA
SELECTABLE LANGUAGE
Jul 19, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Monitor continuously displays the menu option
click on the monitor menu button and change settings after save and exit.
Jul 09, 2009 | HP mx705 17" CRT Monitor
Help! I live in CANADA and accidentally clicked the PAL switch on with my remote control the home theater system model DVA - 8700 set-up and now I can here the sound but I can't see anything to find my way...
Pls try doing a reset by unplugging the unit from the mains for a couple of hours (preferably overnight).
Alternately, you can try hooking it up to a video monitor (capable of RCA/Composite or S-video), a movie camera (switch to external video source), or another TV that is PAL/NTSC capable while configuring it back to NTSC settings.
Additionally, you can try simply pressing the NTSC/PAL button with a few seconds interval while playing a known good NTSC disc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Televison & Video
Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
Mar 04, 2008 | Acer AL2671W 26 in. LCD Television
PAL, NTSC
Can you somehow press on "DEFAULT SETTINGS"? Do you have manual for your TV? Which model you have?
Sep 28, 2007 | Mintek DVA-8700 System
Belkin Hi-Speed USB 2.0 DVD Creator + Sony TRV65E Hi-8 Camcorder
Here is the solution from another group. I hope this helps. Let me know (It sounds like Belkin & M$ have some bugs to deal with) JC QUOTED TEXT There is a God!!!!!!!!!!!! I have just spent HOURS with a USB 2.0 DVD Creator trying to get it to work - the Ulead software that came with it was a piece of crap that I eventually after several tries got to install & then crashed every time I tried to open it - just like many of the posts I have found - could not solve the problem so gave up. I have spent considerable time combing forums trying to find the solution (I hate to be beaten!) - was close to giving up when I found this post - did not solve the problem but set me on the right track, & with a bit (lot) of luck - i am home!!! Here's what I did - the problem IS Windows Movie Maker defaulting back to NSTC. In WMM Set the format to PAL in "Options" - from memory this is in the Tools menu - sorry, I am in the middle of capturing video, so cannot access the menus to check. The only thing you then have to do was advised courtesy of an email reply from Belkin: "In windows movie maker, click on capture from video device and then choose the device and then there should be a configure button. You will need to change the video standard to PAL and then it should capture in colour" Sounds simple enought, but - PROBLEM - you try to do this but you cannot apply the change & it does not take - so you still have capture but no colour. Here is where luck stepped in - I decided I had spent too long trying to make this work so started surfing for alternate capture software. I came across several possibilites & downloaded them. Just picked randomly on one & installed it - beginner's luck!! - about time i got a break! When the software finished installing the program prompted me to install something else that it needed to run, which I did - don't ask me what it was - i was so blown away when i got WMM working that it has completely escaped me! Anyway, I installed the software (& the other required file), opened the software (which was a trial version) & attempted to capture - same problem - sound but no colour - then I recalled about changing to PAL, so went into the setup, changed the video to PAL - & bingo, all OK. I then (for some reason - madness maybe) went back into WMM, configured for PAL as advised, & double bingo - it works!!! - as soon as I clicked on PAL I could see colour video in the preview screen. Actually, I think what made me go back into WMM was that SuperVideoCapture looks & feels VERY similar to WMM . I have since uninstalled the trial software program, & am capturing in WMM with no problems - & in colour. The last piece of the puzzle (after the pain I have gone thru I couldn't bring you this far & not give you the final piece of the puzzle) - the software was SuperVideoCapture & the trial version can be downloaded at download.com - hope this gets around & ends the many headaches that people are having with getting the belkin hardware to work
Aug 29, 2006 | Belkin Hi-Speed USB 2.0 DVD Creator...
Pal capture format
Out of page 26 in the manual: "When you select "preferences" from the list the following window appears on the screen. it offers some general settings for working with ProPix EVE. the check boxes under video standard enable you to specify whether the project is edited in PAL or NTSC." also from the manual page 30 - go to the drop down menu video device, clicking the button on the right gets you into the video input settings dialog box where you can configure the capture device. under the "video standard" pull down menu you can choose PAL. hope this helps, and check back soon because the manual should soon be online on this site. Good luck!
Jan 25, 2006 | Zio Corporation CameraMate RealTime...
Televison & Video Logo
Top Televison & Video Experts
